TRD fake bead lock max tire size w/ lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kontraB, Mar 14, 2013.
  1. Mar 14, 2013 at 4:48 PM
    kontraB
    kontraB [OP] New Member
    Kansas
    So I am about to pull the trigger on a complete OME lift with 885s and dakars and total chaos UCA. I have the TRD fake beadlock rims and I am wondering what the largest size tire is that i can fit with the lift.
    I have searched the forum and found some people say that the rims are 4.5 inch BS and should be able to fit 285/75/16 with the lift without hitting the UCA and some light trimming.
    Can anyone confirm this?
  2. Mar 14, 2013 at 9:30 PM
    Brandon###
    Brandon### Well-Known Member
    You shouldn't need to trim anything for 285s. I think if you go any bigger you will need to start cutting and trimming.
  3. Mar 14, 2013 at 9:37 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    Thats not totally true. Sure you might be able to fit a 285 on the truck for street use only. If you want to use the truck off road 285s will rub a lot without trimming. The wheel well is not really designed for larger tires. To take your tire to full bump you will rub something if the tires are larger then stock.
  4. Mar 15, 2013 at 3:34 PM
    Brandon###
    I've been through Moab and quite a few trails in Colorado and have never rubbed.
    Maybe my Light Racing Upper Control Arms are the reason they've never rubbed, but I would recommend anyone lifting close to 3" invest in UCA's in order to align it properly.
  5. Mar 15, 2013 at 6:30 PM
    eAreEyeSee
    eAreEyeSee Well-Known Member
    Eric
    Aurora CO
    2010 DCSB TRD Off-Road
    Blah Blah Blah. Like your FF team, nobody cares!
    Those wheels sit in more so you'll be fine. I have the same wheels and only had only about 2.5" lift and had both 285 Duratrac and 285 BFG A/T's with absolute no rubbing anywhere. I still run the mudflaps too. I used to have MB wheels with the 4.5" backspacing that everybody says you need and they rubbed like a somovabatch.
  6. Mar 16, 2013 at 5:16 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Pics?
  7. Mar 17, 2013 at 7:08 AM
    eAreEyeSee
    Eric
    Aurora CO
    Sorry, no pics of that set up. I developed the vibration problem and didn't like the ride so I have changed it. I'm back to stock height on 265/75-16's with the same wheels.
  8. Mar 17, 2013 at 7:56 AM
    Brandon###
    Here are a couple of poser pics. Nothing too extreme here. I believe both were taken at fins n things.
  9. Mar 17, 2013 at 7:57 AM
    Brandon###
  10. Mar 25, 2013 at 2:17 PM
    iJDub
    iJDub Well-Known Member
    You guys had 285/75/16 with the TRD bead lock rims and a 3" lift with UCAs and didn't have any rubbing? I thought you'd have to CMC too.
  11. Mar 25, 2013 at 4:34 PM
    Brandon###
    They're actually 285's. No CMC, and it has never rubbed.
    UCA's are required though...
