-   -   2008 Tacoma timing problem (http://www.tacomaworld.com/forum/2nd-gen-tacomas/270195-2008-tacoma-timing-problem.html)
tw1952 03-26-2013 06:07 PM
My truck trys to start and then dies similar to a timing belt slip or break. I undrrstand that I have a timing chain. Does thos happen and what is the fix.
Tw1952
Hugh Morron 03-26-2013 06:18 PM
Check for code first. That will generally lead you in the right direction.
tw1952 03-26-2013 06:23 PM
I am on the side of Mauna Kea and without diagnostic equipment. Any ideas?
Jimmyh 03-26-2013 06:48 PM
Worn timing chains have been known to jump teeth. Usually only in very high mileage engines.
A problem with the VVT system... It could also be lots of things other than the timing.
tw1952 03-26-2013 07:15 PM
Thank you. I suspect a jump in the chain
Same noise as a belt..132000 miles on my 08,all on The Big Island of Hawsii
Fractured 03-26-2013 07:21 PM
The truck would run terrible on a jumped chain tooth, if even at all.
If its a noise- not a driveability issue, it could be a chain guide/ water pump etc.
Kirk1589 03-26-2013 07:24 PM
May be electrical with VVTI I highly doubt the chain jumped it would start sounding like marbles in a glass jar on cold starts. It just won't randomly do this. Anyways how the F do you rack up a 132k on a island honestly
gusher 03-29-2013 05:03 AM
What ended up being the problem???
