Question on Mud Flaps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoVerde742, Mar 27, 2013.
Mud Flaps or no Mud Flaps
Poll closed Apr 26, 2013.
  1. Yeah, keep them on
    49 vote(s)
    39.5%
  2. No way, remove those suckers
    38 vote(s)
    30.6%
  3. It depends
    37 vote(s)
    29.8%
  1. Mar 27, 2013 at 2:35 PM
    TacoVerde742
    TacoVerde742 [OP] Member
    Christian
    Gettysburg, PA
    2013 Double Cab SR5
    Okay, so I've noticed there seems to be a disagreement on the issue as to whether or not the mud flaps should be removed. I haven't done any off-roading and don't plan on it in the near future. I haven't installed a lift or larger tires.
    I've read that the mud flaps can cause damage to the paint, but it seems only in extreme situations.
    So, what the deal?
  2. Mar 27, 2013 at 2:40 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Leave them on and trim them
  3. Mar 27, 2013 at 2:42 PM
    thebrick
    thebrick Well-Known Member
    Frontrange
    06 2.7L Base
    fox 2.0 remote res toytec UCA all pro add a leaf bilstein 5100 all pro standard bumper hid kit
    If you aren't going higher or bigger i don't see why they can't stay. Leave em til you break em.
  4. Mar 27, 2013 at 2:49 PM
    senojeelnodnarb
    senojeelnodnarb Well-Known Member
    Brandon
    Oahu, HI /Canton, NC
    2013 Tacoma DCSB 4x4 TRD OR, 6-Spd Manual
    Fully De-Badged, Mossy Oak seat covers, Fog Light anytime mod, Custom Bed Light Bar, flowmaster 40 series, Plasti-Dipped Grille, Painted Stock TRD Rims, Custom Plate Bumper, High-Lift Bed Mount, Ballacula Trailer Plug Relocate, Rear Seat Dog Platform, sunglasses holder Switch panel, 2" lift, 285/75/R16 Mickey Thompson Baja MTZ, custom sliders, + a shit load more,
    Well I hate how my front flaps almost touched the ground. So they came off. I had the truck in central Texas(really dusty) and after a month when I removed the front the dust/ sans had rubbed the paint bad
  5. Mar 27, 2013 at 2:50 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    ^ This, if you don't offroad. If you do offroad, remove them. If you want to lift with bigger tires, remove them.
    I don't offroad either, however sometimes when pavement is cutup or certain gnarly speed bumps, the front flaps would scrap, so I trimmed both the front and back. I trimmed the backs so they just covered the exhaust, and trimmed the fronts the same length as the backs.
  6. Mar 27, 2013 at 2:59 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    I say at least take the front off. if you wont be going off road you wont have a problem with rocks. i have A/T’s and go off road and hardly ever have rocks hit the rocker panels or doors. I took the front off the 3rd day i had the truck. back came off last summer because most the tabs broke.
    WRONG! the edge of the mud flap and rub the pain off the flair! There is pic in other threads to prove that it can happen. So people that say it can are not morons. I had very slight and small marks on my finder fairs when i took mine off.
  7. Mar 27, 2013 at 3:05 PM
    ScotianPlaid
    ScotianPlaid Member
    NS Canada
    SR5 V6 4x4
    Trimmed the front 4 inches. Don't offroad but do drive some logging roads. the fronts were scrapping on some dips in the road. Seems good now.
  8. Mar 27, 2013 at 3:10 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
  9. Mar 27, 2013 at 3:24 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    ok. and only think they really stop if water(don’t even keep water from getting thrown up) and they stop rocks. if you not off roading and don’t have A/T’s or M/T’s rocks are not a problem. i never had rocks hit when i took them off and had the stock rugged fails. only had rocks start hitting when i got my nitto terra grapplers, and i still hardly ever have rock hit even with off roading. and how are you going to get mark from the tires? unless they are bigger tires (even if they are one size bigger they wont touch( they don’t come close to touching the finders.
    This is what i’m talking about and everyone els. You can’t see it till you take them off.
  10. Mar 27, 2013 at 3:38 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    besides the fact that I cant get away with them removed for safety checks, I've run mine without problems....
    granted, theyre kinda fucked up from all the rocks theyve hit, but they're still there....
  11. Mar 27, 2013 at 3:41 PM
    nammer
    Nam
    Bradenton, Florida
    if you're not offroading, then i wouldn't worry about damage, they're more for keeping your truck cleaner than protecting against damage, i have mine off, i think it makes the truck look taller and gives it a cleaner look (not literal)
  12. Mar 27, 2013 at 3:43 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    fuck safety checks... I keep my rear on for a little bit. then all the plastic clips broke and they were held on by 2 bolts so i just took them off, did not want to risk loosing one on the road or something.
  13. Mar 27, 2013 at 3:49 PM
    OZ-T
    Peter North
    British Columbia
    I have never understood the " take the flaps off before they gouge the paint so instead of that you can chip the shit out of your rocker panel and doors with rocks " arguement
  14. Mar 27, 2013 at 3:50 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    x2
    but it looks better without mudflaps?
    idk
    I like the way mine are.... just always need to remember to never reverse onto them haha
    0a4b743d-e36a-429b-ae76-7100a0a253bd_zps_b721d58fc73d90dd2cb8f7dd912297d2baed4ab3.jpg
  15. Mar 27, 2013 at 3:51 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    this is a 2nd gen topic? oh well.
  16. Mar 27, 2013 at 3:56 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    I've been debating on taking mine off... I guess I'll just leave them on until the break off.
  17. Mar 27, 2013 at 4:09 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    trim a few inches off the fronts :)
  18. Mar 27, 2013 at 8:03 PM
    taco terror
    taco terror 1st gen = best gen
    North Carolina
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    No no no, you guys are all wrong.
    Buy a first gen, they come with flexible mudflaps.
  19. Mar 27, 2013 at 8:22 PM
    Texas Taco
    Texas Taco Well-Known Member
    U.S.
    2016 TRD OR DC 4x4 QS
    Icon stage 4 w/RXT leaf pack and shocks, Icon hydraulic bump stops, LT285/75R16 BFG KO2s, 30" Rigid light bar, HIDs, and window tinting. More to come...
    I don't like how far down the front mudflaps hang down so I used to just have my rear mudflaps on, but decided to trim all 4 about 4 inches or so and install the fronts as well. I offroad moderately and consider it a decent compromise plus I like the way it looks. I run 265/75R16 BFG AT's with 4.5 backspacing and have no rubbing issues with them. If I were to go up to a 285 I'd probably have to remove the fronts. This setup works fine for me. Just like others have said, it all depends mostly on how you plan to use your truck.
  20. Mar 28, 2013 at 4:13 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I vote on but you wouldn't have a problem selling them. I know the drivers behind you would appreciate them on along with some law enforcement.
