mystery noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomalimited, Mar 28, 2013.
  1. Mar 28, 2013 at 3:37 PM
    tacomalimited
    tacomalimited [OP] Well-Known Member
    Northern NJ
    2018 tacoma limited double cab Short bed 4x4.
    I have a weird news coming from what sounds like under my hood. it sounds like a fan propeller sputtering.I don't always hear it, at first I thought it might be the ac/ heat propeller behind the dash, but I'm thinking it can't be that, because I hear it, when I have the ac/ heat controls off.I always leave the setting on defrost/feet, but I hear it even when it's off.I opened the hood and looked, everything seems normal, I'm stumped! anybody have a clue?I have a 2013 4.0 v6 dclb, if that helps, thanx!
  2. Mar 28, 2013 at 4:20 PM
    tacomalimited
    Northern NJ
  3. Mar 28, 2013 at 4:47 PM
    tacomalimited
    Northern NJ
    Oh well, guess I'm the only one with this problem.
  4. Mar 28, 2013 at 5:02 PM
    Bauer
    Bauer Member
    Texas
    09 PreRunner
    My 2009 DC has kinda loud ticking at lower rpm's, just figured these have noisy valvetrain.
  5. Mar 28, 2013 at 5:06 PM
    tacomalimited
    Northern NJ
    it's not a ticking though, it's like a sputtering fan,I really don't know any other way to describe it.I thought it might be the cooling fan in front of the radiator, but, when I opened the hood with the engine running,I didn't notice anything weird, except maybe the hot pink on the fan,I mean,really?:eek: I only notice it when I'm stopped at a light, and its not all the time, if I'm moving,I don't hear it!
  6. Mar 28, 2013 at 5:09 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Steve
    Buffalo NY
    2010 RC 2.7 4x4
    BUCKLE UP! It makes it harder for Aliens to pull you out of your Truck.
    You say "I always leave the setting on defrost/feet" Doesn't that mean the air conditioning is cycling on and off?
  7. Mar 28, 2013 at 5:37 PM
    tacomalimited
    Northern NJ
    I don't know,I don't think so,I could be wrong. Do you think it would matter?I actually meant defog/feet, sorry, not sure if it matters, I'm stumped!
  8. Mar 28, 2013 at 5:44 PM
    Steves104x4
    Steve
    Buffalo NY
    2010 RC 2.7 4x4
    Turn the dial to "vent" and see if it still makes that noise.
  9. Mar 28, 2013 at 5:46 PM
    tacomalimited
    Northern NJ
    which one is vent? You mean the recycle button?
  10. Mar 28, 2013 at 5:48 PM
    Steves104x4
    Steve
    Buffalo NY
    2010 RC 2.7 4x4
    No. The dial to make air come out the vents toward your face.
  11. Mar 28, 2013 at 5:51 PM
    WTFaulkner
    WTFaulkner Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
    does it happen when you drive your truck for the first time of the day and then stop not long after warming up fully because mine has a similar sound only when in the morning or when i first drive the truck for the day,it happens when i press the gass pedal or accelerate kinda heavy for the first 5 min on the way to work
  12. Mar 28, 2013 at 6:13 PM
    tacomalimited
    Northern NJ
    no, it's not just the morning,I hear it in the morning and aftet I drove 70 miles home, it's not all the time, and, it's only when idiling at a light .
  13. Mar 28, 2013 at 6:15 PM
    tacomalimited
    Northern NJ
    oh ok, I'll give that a try tomorrow, why ? do you think that would matter?
  14. Mar 28, 2013 at 8:22 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is the hydraulic fan clutch..
  15. Mar 28, 2013 at 10:10 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    On both defrost positions the truck runs the AC compressor. However if you turned the fan off the compressor would have shut off too.
  16. Mar 29, 2013 at 10:08 AM
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    OHHHH:D good to know hah thanks!!
    Gotta love TW
  17. Mar 29, 2013 at 10:33 AM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    I have noticed something similar on my 2012. Didn't hear it or notice until about 8000 miles. I can only hear it when say idle at lights. It sounds like a muffled low tone fast sputtering fan I guess. It will come on for about 15 seconds or more and then it will go away.
    I don't notice at all times, and it will sound/appear at any point in the day/driving. It is too quiet to hear if driving, and you have to have the radio off or low. You can almost feel it in the seat. It as if a system/component is cycling/purging. First thought it was coming from behind the passenger rear seat, but now think it originates from in front of passenger under hood. No source found yet here either.
  18. Mar 29, 2013 at 4:55 PM
    tacomalimited
    Northern NJ
    Exactly!!! Is it normal, or should I have it looked at?
  19. Mar 29, 2013 at 4:55 PM
    tacomalimited
    Northern NJ
    is it normal?
  20. Mar 29, 2013 at 5:16 PM
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    bumpppp!
