-   -   Need a 8" lift.... (http://www.tacomaworld.com/forum/2nd-gen-tacomas/271446-need-8-lift.html)
Hipespipes 04-03-2013 09:18 AM
Need a 8" lift....
Does anybody make a 8" lift? If so whats the price? Sorry guys its a 2013 dc 4x4.
Crosis 04-03-2013 09:24 AM
You need to say what vehicle you want it for. Otherwise all we can do is suggest you Google it... which should have been your first step.
Monster Coma 04-03-2013 09:27 AM
6" DB lift, or if you are a prerunner you can get 8" with spindles I believe
Warputer 04-03-2013 09:33 AM
Really the only way 8" is possible, would be by stacking multiple lifts....
6" drop bracket lift + 2" leveling kit(spacers)
6" drop bracket lift + 2 or 3" body lift
6" drop bracket lift + 2.5 to 3" suspension lift (coils, shocks)
and if you're 2 wheel drive there are even more options with spindle kits.
Many options & brands are available to accomplish this. Many guys on here will discourage you from stacking lifts together but quite a few have done it.
Originally Posted by Crosis (Post 6687496)
:rotfl:
Large 04-03-2013 09:35 AM
I can already see this thread becoming a :crapstorm: so I guess I'll whip out the :popcorn:
BORNWILDGUY 04-03-2013 09:43 AM
6" db kit with with ome 884 or 885 up front and custom rear springs
Manwithoutaplan 04-03-2013 09:44 AM
same here Brace yourself OP.
Warputer 04-03-2013 11:16 AM
http://i306.photobucket.com/albums/n.../leghumper.gif
Manwithoutaplan 04-03-2013 11:18 AM
hey ^
Sandman614 04-03-2013 11:19 AM
Are the curbs really that tall where you are? 8" wow :eek:.. How about them CV angles?
Manwithoutaplan 04-03-2013 11:19 AM
they are made out of cement which was rock at one point.
Sandman614 04-03-2013 11:23 AM
What's the Need for 8", Just need to show someone up that has a 6"? And really how bad would the CV angles be with that, if 4x4?
Manwithoutaplan 04-03-2013 11:24 AM
i know 6 inch lifts are point less but the cv angle would not be to bad. Because on the 6 inch the cv angles are stock level.
Sandman614 04-03-2013 11:31 AM
So 8" would be the same as a 2" lift, as far as CVs are concerned?
Manwithoutaplan 04-03-2013 11:36 AM
i think so.
vette6991 04-03-2013 11:37 AM
sas
Manwithoutaplan 04-03-2013 11:38 AM
or this ^ then you would not have to worry about cvs :D.
Pugga 04-03-2013 11:53 AM
Cement is a soft powder. If your curbs are made out of that, I wouldn't worry about a lift. Concrete, on the other hand, is a little more rigid :D
Screw the CV's, what about the drive shafts. The CV's between the transfer case and the wheel bearing would be similar to a truck with a 2" lift. The shaft between the transfer case and the differentials would be operating at an angle I'm sure it wouldn't be happy about and that's assuming the stock shafts even have enough play to allow that much lift (which I doubt that they do). The rear would likely require a drive shaft spacer or a new shaft altogether.
I have to ask, why does one NEED 8" of lift?
Kirk1589 04-03-2013 11:56 AM
SAS
steve o 77 04-03-2013 12:01 PM
http://www.tacomaworld.com/gallery/d...m/100_2719.jpg
http://www.tacomaworld.com/forum/1st...lest-taco.html
lol
