opinions on lift build 13 trd or
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dirtrider262, Apr 3, 2013.
  1. Apr 3, 2013 at 6:06 PM
    dirtrider262
    dirtrider262 [OP] Member
    southern oregon
    2013 MGM TRD OR DCSB 4.0 6SPEED
    this is my first tacoma a 2013 trd or mgm 6 speed and am open to advice .
    lift build.
    OME 885x
    bilstein 5100 @0
    1/4 SPACER FOR TACO LEAN
    FRONT DIFF DROP
    CARRIER BEARING DROP
    SWAY BAR RELOCATE
    WHEELERS 3 HD ADD LEAF
    MORE 5100s
    265-75-16 TKOs
    am hoping for a 2.5" at front and 1.75" at rear and after all that i m hoping for good numbers on my alignment thanks for any help #262
  2. Apr 4, 2013 at 6:13 AM
    dirtrider262
    southern oregon
    ome 885-160$
    1/4 spacer-7.50$
    diff drop-32.00$
    carrier bearing drop -32.00$
    sway bar relocate -35.00$
    wheelers 3 leaf h.d -159.00$
    front billies -150.00$
    rear billes 159.004
    699.50 $ total for lift and i ll run stock tire until end of summer then do the tko s
  3. Apr 4, 2013 at 6:15 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    You can skip the diff drop, its pretty much useless in most cases
  4. Apr 4, 2013 at 9:14 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Don't forget your UCAs if you want to keep your alignment.
