Alignment are these numbers good??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDMike66, Apr 3, 2013.
  1. Apr 3, 2013 at 11:22 PM
    TRDMike66
    TRDMike66 [OP] Well-Known Member
    so. cal.
    2007 TRD SR5 Package
    Bilstiens 5100's all the way around, wet okale seat covers, red led interior lights,Level 8 Guardians wrapped with Hankook Dynapro's 260/70/17 and 35mm caps/black gorilla lugs,sock monkey TRD So Cal Bedside Decals BANKS-Monster Cat-Back Exhaust, Light Racing Upper Control Arms, One of a kind satoshi grille thin lip by Homer Taco.
    [​IMG]First time
    they said they couldn't get any better I told them go try again and they got me this the second time i was wondering if this is good?
    second time through
  2. Apr 3, 2013 at 11:24 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Pics no worky
  3. Apr 3, 2013 at 11:30 PM
    TRDMike66
    so. cal.
    fixed i think
  4. Apr 3, 2013 at 11:31 PM
    OZ-T
    Peter North
    British Columbia
    Hard to read but your caster seems pretty low
  5. Apr 3, 2013 at 11:32 PM
    OZ-T
    Peter North
    British Columbia
    What are your Billies set at ?
  6. Apr 3, 2013 at 11:34 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    aim for 2.5ish caster
  7. Apr 3, 2013 at 11:34 PM
    TRDMike66
    so. cal.
    highest setting
  8. Apr 3, 2013 at 11:35 PM
    OZ-T
    Peter North
    British Columbia
    Stock UCA's ?
    Were your alignment cams seized ?
  9. Apr 3, 2013 at 11:41 PM
    TRDMike66
    so. cal.
    stock uca i don't know are these bad setting if so i can go back. I put up better picture. my billies are at top level with stock coils
  10. Apr 3, 2013 at 11:43 PM
    BMOC
    Paden
    Phoenix, AZ
    think you need aftermarket uca's to get into spec dude. (light racing/camburg/total chaos)
    or lower the truck.
  11. Apr 3, 2013 at 11:48 PM
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    I am not certain about your numbers, but I figured I would give you something to compare again.
    The truck is a 2013, not a 2012 (the shop probably didnt have 2013 in their computer), and the tires are 265/70/17 (although wouldnt make a difference in alignment IMHO). Bilstein 5100's in front at 1.75 and rear is normal 0. 2013 has the TSB, so In my TRD Sport I have 3 leafs + the 1 upside down one. Rear Firestone RideRite airbags, but only 5psi in them, so basically non-existent. Nothing else done in the suspension.
  12. Apr 3, 2013 at 11:51 PM
    TRDMike66
    so. cal.
    how bad is my truck going to ride? also how are the tires going to wear?
  13. Apr 3, 2013 at 11:52 PM
    OZ-T
    Peter North
    British Columbia
    Camber and toe effect tire wear not caster , your camber and toe look fine
    Take it for a spin and see how it tracks
  14. Apr 3, 2013 at 11:53 PM
    TRDMike66
    so. cal.
    so basically i need uca to get back in specs? tracking do mean it will wander on the highway I am new to this stuff.
  15. Apr 3, 2013 at 11:55 PM
    OZ-T
    Peter North
    British Columbia
    It may feel fine , but you may have little or no caster adjustment left with the stock UCA's , so , maybe
  16. Apr 3, 2013 at 11:55 PM
    OZ-T
    Peter North
    British Columbia
    Yes , wander at speed / track straight
  17. Apr 3, 2013 at 11:57 PM
    TRDMike66
    so. cal.
    ok what uca do you suggest? one with reg ball joint or uni ball?
  18. Apr 4, 2013 at 12:00 AM
    OZ-T
    Peter North
    British Columbia
    Depends on your end use
    I personally have LR UCA's , which are an adjustable ball joint style , because I was more concerned with getting the alignment in spec and I liked the fact that the BJ was booted , versus more articulation with a uniball
  19. Apr 4, 2013 at 12:02 AM
    TRDMike66
    so. cal.
  20. Apr 4, 2013 at 12:08 AM
    OZ-T
    Peter North
    British Columbia
    I believe they both carry LR UCA's but I think there is a good deal to be had on them , hang on
