help!! removing fenders... water on the floor!!! 2005 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by davies604, Apr 7, 2013.
  1. Apr 7, 2013 at 5:40 PM
    davies604
    davies604 [OP] Well-Known Member
    Marcus
    vancouver
    Black On Black TRD OFF-ROAD
    285/75/16 Dura Tracs 3" OME full suspention lift Dakars in rear light Racing control arms 1" 1/4 Spider wheel spacers Blacked powder coat stock wheels Magna flow pro of road cat back K&N cold air
    I have done research after finding water on my floor both driver and passenger .. Apperiantly there was a tsb BO004-05 for the cowls I need to remove my fenders what is required???? Anyone have a link with photos of this operation
    For anyone who doesn't know after you do the pinch weld inside fender reseal the whole thing mine was leaking lie crazy both sides buy some automotive seam sealer and go.to town on the whole pinch weld.. Crank up heat inside roll all windows up and cover the weld and surrounding area with very soapy water it will bubble all air leaks
  2. Apr 7, 2013 at 6:06 PM
    Jux
    Jux :D
    Steve
    Northern Colorado
    2013 V6 4x4 SW DCSB TRD OR
  3. Apr 8, 2013 at 1:45 PM
    davies604
    Marcus
    vancouver
    I almost got.the fende off but it seems like I need to take door off also is this true or am I tripping?
  4. Apr 8, 2013 at 8:58 PM
    davies604
    Marcus
    vancouver
    Figured it out
  5. Jan 4, 2014 at 12:58 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    Wanna do or could you do a write up on this? I'm about to be replacing mine and would like to have a guide on the removal process...
  6. Jan 6, 2014 at 7:14 AM
    davies604
    Marcus
    vancouver
    Sorry I meant to say I figured out my leak I did not end up removing the fenders as I remember there was some really weird bolts on the inside
