URD FUEL PUMP which is the best?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kauai808boy, Apr 8, 2013.
  1. Apr 8, 2013 at 12:54 AM
    kauai808boy
    kauai808boy [OP] Member
    icon/fox 3inch lift, flow-master super 40, jba shorty headers
    was gona order my fuel pump kit for my 07 stock super charged tacoma but couldn't decide on which fuel pump would be the most reliable brand to go with so im asking the world what you think is best of the best
    its either
    Walbro 255 LPH High Pressure fuel pump
    AEM 320 LPH pump
    DeatschWerks 255 or 320 LPH pump
    AeroMotive 340 LPH pump
  2. Apr 8, 2013 at 12:58 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I've havent heard of any real problems with the walbro
  3. Apr 8, 2013 at 1:25 AM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    You'll be fine with the Walbro 255 HP (alot of people use this one)
    Unless you plan on jumping into higher horsepower with the supercharger then you should get the Aeromotive 340 (this is the pump I use) for more flow
    Truthfully you can't go wrong with any of them
  4. Apr 8, 2013 at 6:33 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I've heard of a couple folks who have had issues with the Walbro..I went with the 320 AEM for a little bit of extra capacity from a pump that I've had good luck with.
  5. Jun 3, 2014 at 9:41 PM
    2wheelnut
    2wheelnut Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    Didn't want to open a new thread but was wondering how bad mileage was affected with the AEM 320? I am about to put one in my truck along with the 2.85 pulley...
  6. Jun 4, 2014 at 4:46 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I didn't note any real change w/ the fuel pump. The blower took less then 1 mpg off so I 'm between 15.5 and 16.5 driving like I normally do.
  7. Jun 19, 2014 at 5:52 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    A larger fuel pump won't affect gas mileage. The injectors are still only going to flow the necessary amount, based off of the fuel pressure and target AFR. In Close loop.
