Camper Shell questions
Discussion in 'Tonneau Covers, Caps and Shells' started by rhavin42, Apr 15, 2013.
  1. Apr 15, 2013 at 11:19 AM
    rhavin42
    rhavin42 [OP] Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    I'm considering getting a shell for my truck, and came across one on craigslist today. I have a couple questions for you guys that have shells.
    First question does this shell look like the right one for my truck (09 DCLB) I'm asking because in the pictures it looks like the guy has removed the bedrail caps in order to install the shell, is this normal? or is the shell supposed to sit ontop of the bedrail caps?
    I've looked through a bunch of member photos on here and can't quite tell if the their shells are sitting ontop of the rail caps or if they were taken off.
    Also does anyone know if you can replace the non sliding rear window to one that slides open for incab access from the bed.
    All your help is appreciated!
    http://phoenix.craigslist.org/evl/for/3744660835.html
    3Kf3Na3H45Kd5He5J5d4f3e205df3735511d1_zp_325adeed9c20ec8a6fb2140e87402465e0729d99.jpg
    3Fe3La3N75Id5H95J5d4f19b3e41cde911a75_zp_261e96d20eeb69394a262dd72ca3a110e9fa909b.jpg
    3F83I33L75I65H85Mfd4f82e2b806801618e8_zp_987f0757919de6f60212b0b0519450d39c704b95.jpg
    3E23I23M25N55Gb5Mad4faea8107fd88118b4_zp_030d9029ae5ac75d244535892d6299d0361519d7.jpg
  2. Apr 15, 2013 at 11:23 AM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    thats not the right cap. That is for 1st gens. He had to remove the bed rails because it is too narrow for the bed.
    I'm sure functionally it will work fine, but because its for a different truck it will look funny and probably leak
  3. Apr 15, 2013 at 11:23 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    That doesn't fit
  4. Apr 15, 2013 at 11:25 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Looks like its for a 1st gen Tacoma. I just bought a used Leer and it sits on top of the plastic bed rails. It has about an inch skirt on the sides to keep the water out, which is why you can't see the plastic bed rails when you look at other members trucks. I would pass if I were you!
  5. Apr 15, 2013 at 11:26 AM
    Madcat207
    Madcat207 Well-Known Member
    FL
    08 Double Cab Long Bed Sport
    I have that model shell, and no, that is not fitting correctly. You do not have to remove the caps.. it will sit perfectly over them.
    Do not buy a cap that says it fits all these various brands of trucks. You need one made for our bed. Also, note that a shell for the regular cab will not work on an access cab or double cab (the cab has a different shape).
    Hope it helps!
  6. Apr 15, 2013 at 11:31 AM
    rhavin42
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    Thanks guys. I knew something didn't look quite right with it.
    I knew it was too good to be true, being the correct color and bed length :)
    I'll keep on looking.
  7. Apr 15, 2013 at 9:51 PM
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    Here's how it should look like. Same year and model you have.
    It's for sale too. Too bad you're so far away.
  8. May 17, 2015 at 2:01 PM
    TunTavernTactical
    TunTavernTactical Active Member
    Sgt B
    NC
    Sport 4x4
    This may be a stupid question- I am a TACO FNG... Would a shell for an access cab long bed fit right on a double cab long bed?
  9. May 17, 2015 at 2:16 PM
    Red_Taco33
    Red_Taco33 Well-Known Member
    Upstate New York
    2021 TRD Off-Road MT
    Technically, they should be sitting on top of bed rail caps. Otherwise the bed could be scratched and the cap could slide around.
  10. May 17, 2015 at 2:21 PM
    OZ-T
    Peter North
    British Columbia
    Yes
