anti-sway bars built in
Discussion in '2nd Gen. Tacomas (2005-2015)' started by erm626, Apr 19, 2013.
  1. Apr 19, 2013 at 12:53 PM
    erm626
    erm626 [OP] Well-Known Member
    Ed
    Norfolk, Virginia
    Tacoma 4x4 SR5
    Access Tonneau Cover, EGR window Visors,Trail FX Step Bars
    I know this info is in here some where, But here goes !! Does the 2010 Tacoma have built in, anti sway along with the anti-lock brakes ? Or do I need to install a set ? 2010 Taco w/ tow package
    __________________
  2. Apr 19, 2013 at 12:59 PM
    theboy12
    theboy12 The Answer is 42, But What is the Question?
    Jon
    Redding, CA
    2005 Tacoma TRD Sport DCLB
    King 2.5 Remote Resi'sand rear 2.0s, Dakar Pack, TRD 1st Gen air intake, Stealth 6's wraped in DynaPro ATms 285/70R17s, SnugTop, ALL Pro Front bumper, Brute Fab HC Rear Bumper, Hella Black Magic Lights, Bedslide 1000
    It has them. I'm assuming you have a six lug. Look under the front end and you'll notice the bar. Many owners who like to off road take them off to increase the independent response and articulation of the suspension in the front.
    -Jon
  3. Apr 19, 2013 at 3:30 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Only on the front
  4. Apr 19, 2013 at 3:51 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Are you talking about trailer anti-sway like a ford? If so, no.
  5. Apr 19, 2013 at 4:07 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    The more you know...
  6. Apr 19, 2013 at 5:45 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    ok, so apparently your truck does not have trailer anti-sway. your truck has a sway-bar in the front, for the truck. abs is 4-wheel for the truck. if your talking about abs for a trailer, I believe that would be determined by your brake controller which would not come with the truck from factory. factory tow package does however, come with a 7 pin connector, with brake wiring all the way up to the driver kick panel so that you could easily plug in the brake controller of your choice
  7. Apr 20, 2013 at 5:37 AM
    erm626
    Ed
    Norfolk, Virginia
    Tacoma 4x4 SR5
    So if the 2010 Taco does not have a rear sway bar. Is it needed when pulling a travel trailer ?
  8. Apr 20, 2013 at 5:52 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Short answer,
    No you don't need one to tow.
