-   -   2008 Taco Stuck In Park... (http://www.tacomaworld.com/forum/2nd-gen-tacomas/274465-2008-taco-stuck-park.html)
mojoe 04-22-2013 05:45 PM
Edit to ADD: I Goofed on the title... it's a 2006.
So I've had this issue before that was resolved by following a thread here earlier. It was in fact the STOP 10A fuse that blew. Fast forward to today and I have no clue what the deal is.
Solutions I've tried so far
Checked all the fuses, multiple times including:
10A IG1
7.5 A ACC
10A STOP
10A IG1 No.2
I've tried pressing the button next to the shifter with zero results.
I don't have an owner's manual, but will get one very soon, so I do not have anything else to go on besides reading problems people had in the past. At the moment I'm stuck at work trying to find a switch somewhere by the pedal....
Additional note. I do have an aftermarket tow package.
Leoffensive 04-22-2013 05:50 PM
interesting.
so that one 10a fuse is ok?
weird that override button wont work
Leoffensive 04-22-2013 05:51 PM
call the toyota dealer and see if they can suggest something over the phone
Jimmyh 04-22-2013 06:09 PM
If the button isn't working it seems that the shifter linkage is frozen or binding.
Beavis0076 04-22-2013 06:11 PM
Brake lights working?
mojoe 04-22-2013 06:15 PM
Sounds expensive....
Yes all lights are operational.
Beavis0076 04-22-2013 06:20 PM
Hm... I was thinking brake light switch. Did u try rocking the truck back and forth a little.. Then try the button again? I think u have to put your key in the slot??
mojoe 04-22-2013 06:24 PM
I have not tried rocking the truck yet. As far as the button pressing, I always have the key in the slot and the truck is turned on and running when I attempt the button push.
Edit: Tried the rocking....nothing :-(
I found this thread, but there was no solution posted :-(
http://www.tacomaworld.com/forum/2nd...r-shifter.html
Beavis0076 04-22-2013 06:38 PM
no, i meant the slot for the key near the button.. but I just ran out to my truck and the taco only has the button.. make sure you lifted the cap off the button.. other than that.. might be a tow job..
mojoe 04-22-2013 06:50 PM
yeah the tab is lifted and the button is exposed.
Side Note... If I push really hard it goes into gear BUT there is a very loud thud.
Beavis0076 04-22-2013 06:52 PM
im out of ideas.. :-(
169.254.255.201 04-22-2013 06:57 PM
What were you doing in a park?? Pretty sure those are only for walkers. .:D
Had to.
Do you hear anything underneath when you try to shift? Well have someone else shift.
mojoe 04-22-2013 08:25 PM
Thank you guys so much for the input. I applied brute force to get the Tacoma in Drive and noticed a thud coming from the shifter area. I was able to drive the truck the whole way home without a problem.
So my line of thinking right now is that there is something blocking the shifter from making the transition from park. Evidence so far supports that; No blown fuses, No slippage in transmission and I hear a faint click in the shifter area when brake is applied - so that must mean something is disengaging.
So I followed the awesome tutorial here: Center Console Removal
Here is a pic from the shifter area. Note: The flash made it look disgusting...sorry. But it does look like some rubbing is occurring when the shifter is being engaged.
http://i.imgur.com/9l7TMkm.jpg
Any further suggestions would be greatly appreciated.
t_e 04-22-2013 08:30 PM
Run over anything? check the linkage to the tranny? When my 06 wouldnt shift out of park it was the brake switch but pressing the button got me out of park.
mojoe 04-22-2013 10:40 PM
Everything right now points to Shift Interlock Solenoid. I'm currently trying to find whats involved with it's replacement.
maykevin5 04-23-2013 12:06 PM
sounds like the solenoid wasn't working and then you finished it off with a bang.
mojoe 04-23-2013 03:53 PM
So I've been calling around and shops want $300+ for the shift interlock solenoid part :-( The guy did say if the override doesn't work then there's another culprit. Of all the places I called everybody seemed surprised it was a "possible" solenoid because they never EVER had to replace one.
I have a brake light switch on order for pickup tomorrow...
Beavis0076 04-23-2013 04:20 PM
I would take it to a shop.. at this point you seem to be throwing parts at it.. and that could get espensive quick. have to taken it apart more to see if something like change or something fell down there? or crawled underneith to have a good look see?
Jimmyh 04-24-2013 02:14 AM
When you pressed the brake and heard the click, the click was the solenoid unlocking the shifter. IMO that takes the solenoid and the brake switch out of it.
maykevin5 04-24-2013 07:15 AM
get one out of a junk yard $10, i'm sure the 2nd gens are all the same.
