2013 Tilt Steering Wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by garrett490, Jun 12, 2013.
  1. Jun 12, 2013 at 4:33 PM
    garrett490
    garrett490 [OP] Member
    I searched and searched with no luck. Sorry to start a new thread if this is covered else where.
    I test drove a 2013 DC OR. Hopped in and went to tilt the wheel down and it hit the stop much higher than I normally like my steering wheels. Anyone else notice this? Are all they 05's and newer identical when it comes to how far down the wheel will tilt? As far as I remember the gen 1 tilts down right where I like it. Any way to fix this issue because I'm stuck between the gen 1 and early gen 2s right now. The 2013 is out of the running due to how high the wheel was when tilted all the way down...felt like a school bus.
  2. Jun 12, 2013 at 5:46 PM
    JdevTac
    JdevTac Bawnjourno
    Josh
    GA/WA
    2nd gen
    My steering wheel tilts down the same as my dads 04, so I have no idea what the deal was. Bad wheel lol?
    But seriously, I just pull the tab under the wheel and it adjusts down plenty low. I am 5'9" for reference, and like my wheel lined up so it encapsulates the gauges without obstruction.
    EDIT: best picture I have of how mine is adjusted, and you can see I have a full inch or so gap below the wheel for more adjustment if I wanted it lower.
  3. Jun 12, 2013 at 6:43 PM
    Plain Jane Taco
    Plain Jane Taco ALL human beings deserve equal treatment
    USA
    It's telescopic as well. Maybe between the 2 adjustments you can find a position you can live with.
  4. Jun 12, 2013 at 7:52 PM
    EF
    EF Well-Known Member
    Upstate NY
    2015 TRD Off Road Blue Ribbon
    That shift lever looks like it came from Adam & Eve.com. Is that stock for 2012 up?
    Not much adjustment in my 2008 wheel either. Not really needed though.
  5. Jun 12, 2013 at 8:00 PM
    JdevTac
    JdevTac Bawnjourno
    Josh
    GA/WA
    2nd gen
    Lol no its an FJ Crusier shifter, but thanks for the dildo chuckle:p
