-   -   05- 09 Engine mount replacement (http://www.tacomaworld.com/forum/2nd-gen-tacomas/283190-05-09-engine-mount-replacement.html)
Azntrutek 06-21-2013 08:35 AM
2 Attachment(s)
Have any tacoma's owners member from 2005-2009 model year
Replace your tacoma engine mount yet ?. Mine is 2008 Dbl cab
V6 4.0 short bed. she has 109k miles on her clock . I have had done
couples preventives maintenances for her lately such as
Flushed coolant, power steering fluid, brake fluid, front/rear differential,
T-case oils, drive belt, ESGS bushing and both front wheel bearing. Also i have replaced the water pump as the same time i flushed the coolant. I am thinking about replacing all (5) U-joint, center carrier bearing and engine mount next.
Do i need any special tools to replace the engine mount and how hard is the job. Have never done it before that why i am kinda hesitates. Appreciates for
any input. Thanks.
