Need Help with low speed Vibration/rumble
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kylec82, Jun 22, 2013.
  1. Jun 22, 2013 at 9:55 AM
    Kylec82
    Kylec82 [OP] Jack of all trades, Master of none!
    Kyle
    Huxley, IA
    08 TRD Sport Dbl Cab
    Weathertech Floormats, Bak RollX Tonneau,Blacked out emblems, Powder coated wheels
    I have a 08 double cab TRD sport 4X4 no lift with approx 82k. I am getting a low speed vibration especially while cornering, by low speed I me less than 5mph my best guess is around 3mph. I can make it do it by doing tight turns in a parking lot, it is enough of a vibration that you can feel it in the seat and if there is any thing in the bed it'll rumble. I am also getting a vibration at 15mph which I know that there is a TSB out for. I'm not as concerned about that as it is not very noticable unless your looking for it. I have been doing my research and have tried most everything, to no avail. Here is what I have done.
    -Changed gear lube, running Mobil 1 75W90 and Limited slip additive.
    -Rebuilt drive shaft (3 u-joints & carrier bearing).
    - Drove with rear shaft removed no vibration!
    Any Ideas or help would be very much appreciated.
  2. Jun 22, 2013 at 10:23 AM
    Cmyifyc87
    Cmyifyc87 Well-Known Member
    Md
    Tacoma 4x4 double cab
    6 in susp. Lift 3 in body lift, 20' XDs, exhaust, tbs, cai, jet MAF. uni-chip tuned with cai and exhaust. pending headers...
    maybe it could be the hub bearings?? or the tie rod ends i know i had some what of the same problem, it was a loose tie rod end the led to the bearing going bad. after a days work i had the bearing replaced an luckily the tie rod threads didnt strip out i just tightend it up. good luck with the problem though hope you get it figured out.
  3. Jan 23, 2014 at 7:51 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Did you ever have any luck with this?
  4. Jan 23, 2014 at 9:01 AM
    Kylec82
    Kyle
    Huxley, IA
    I haven't noticed it since the weather has turned cold, but that could have to do with the roads being slick.
