-   -   Camburg LT Coilover Issues (http://www.tacomaworld.com/forum/2nd-gen-tacomas/300324-camburg-lt-coilover-issues.html)
ls1 prerunner 10-26-2013 10:27 PM
Any one running the Sway-A-Way coilovers on their Camburg LT kit? I can't seem to be able to put the reservior at a place that wouldn't interfere with the coil spring or with the upper control arm. It has a 90* swivel only on the hose, I keep only finding pictures of Fox coilovers and they have the 90* swivel with a 90* fitting. Anyone on here that can provide input? Did Sway-A-Way send me the wrong fittings or am I doing missing something?
Any help is much appreciated! Cheers :D
KayStrait 10-29-2013 12:21 PM
2 Attachment(s)
Here are some pictures I round up of the 90 degree fitting for the SAW reservoir. It is very similar to the FOX r/r coilover.
ls1 prerunner 11-01-2013 09:56 PM
Thanks Kayla! Hopefully you can help me with this question too, around what area of the frame does the limit strap tab weld on? The kit came with 10" straps and they seem way too short unless I mount maybe under the frame. I have some 12" straps from my race truck and those seem to fit better if I want to place the tab on the side of the frame.
MonkeyProof 11-01-2013 10:31 PM
this would be a better place to post Long Travel questions. most (lol) are very knowledgeable and have vast amounts of LT experience........
http://www.tacomaworld.com/forum/lon...ml#post7651501
