Opinions on Intake & Exhaust system: MPG/HP vs Cost?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Death Proof, Jan 19, 2014.
  1. Jan 19, 2014 at 9:13 PM
    Death Proof
    Death Proof [OP] Active Member
    SoCal
    PreRunner
    What Intake & Exhaust systems have you found to best increase in MPG/HP vs the purchase investment?
    I've found in the past, I've spent a lot (on certain setups) for somewhere in the neighborhood of 10% gains.
    :cool:
  2. Jan 19, 2014 at 9:20 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    The best ones are fully boxed intakes, and urd/dynamax/afe/trd/borla/aero turbine are all popular for exhaust
  3. Jan 19, 2014 at 9:32 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    They won't improve mileage at all, and will make it worse. Free flowing exhaust and intake will make any engine run rich. The mileage improvement occurs when you tune with these less restrictive devices in place, and even then will take many thousands of miles to pay off. You can buy a lot of gas for the ~$1000 intake, exhaust, and tuning cost.
    http://urdusa.com/Electronics-Perfo....html?osCsid=962c559d2bcbb692c5b93591b9834bbc
  4. Jan 19, 2014 at 11:32 PM
    rruhl48
    rruhl48 Active Member
    Rick
    union county NJ
    07 access AFE 3 inch volant ram air. sounds.p
    AFE 3 inch sounds amazing.. volant ram air intake
    I have the 3inch AFE stainless cat back and it with out a doubt is the most.beautiful sounding exhaust ive ever heard on our trucks. Also I have the volant ram air.intake
  5. Jan 19, 2014 at 11:47 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    not so low, not so slow 2006 6 lug
    stockish
    Mods listed in my build
    Mpg avg on highway is 21mpg using gps
    HP is yet to be seen because any hp claims are worthless without a dyno slip and I havent been on rollers yet.
  6. Jan 20, 2014 at 7:51 AM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    I'm installing an MBRP dual system, not because I think it will give any functional improvements, but because I grew up in the 60's when any V-type engine HAD to have duals. Didn't matter if it was a '40 Ford Flathead or a 409 Chevy with dual quads. (Hey, everyone has to have justification for what they do and mine is as ridiculous as anybody else's.) I know I won't recoup the cost ever, but I'll also keep the stock system to put back on later if I need to.
  7. Jan 20, 2014 at 8:10 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Then you are doing it for the right reason. I run an intake and exhaust too, for the same reason. It sounds nice around redline. Having tuned lots of 1GR-FE's with an actual wideband gauge I can assure you these mods make the motor run rich. Tuning really improves how these motors run...
