Parking brake seized?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bpayne97, Jan 17, 2015.
  1. Jan 17, 2015 at 6:04 PM
    bpayne97
    bpayne97 [OP] Well-Known Member
    McAllen, TX
    06 TRD OR 4x4 Debadged
    URD SS Kit and TRD shift knob, rearview mirror bracket, Fox 2.0 coilovers and smooth bodies
    At the lake and launched the boat. Got back, loaded up and came back to the cabin, no problem. Moved my truck 50' and parked now it won't move? Anyone experience that?
  2. Jan 17, 2015 at 7:28 PM
    Calypso699
    Calypso699 Member
    I've had this happen to me after washing my truck and parking it overnight. Once it was so bad it took about 30 minutes to disengage. I kept pressing the gas while in drive until it finally broke itself loose. Not sure if I did any permanent damage but I was pissed at the time. I've noticed a pattern though...in all cases my truck was parked overnight on a slope (driveway or hill).
  3. Jan 17, 2015 at 7:32 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    Do you use your parking brake often? The reason I ask is I never did when I had an auto, now thar I have a 6 speed I use it every single time I get out.
    I wonder if it has to do with rust or residue on the mechanical bits
  4. Jan 17, 2015 at 7:35 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    put it in reverse, then into drive. My truck does that when I put it away right after a bath.
  5. Jan 17, 2015 at 7:35 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    They do it sometimes, be it ice or rust holding them. Try alternating D and R. Many break loose when put in R. Mine has done it twice.
  6. Jan 17, 2015 at 7:56 PM
    Calypso699
    Calypso699 Member
    I'll remember the tip about putting it in reverse for the next time it happens.
    @jackwithcorona - I got in the habit of using it way back when...not sure if I should or not with an auto but since I park on hills occasionally I like to have it on.
  7. Jan 17, 2015 at 8:06 PM
    jackwithcorona
    Eastern Mass
    13 DCSB SR5 4x4
    It's definitely a good habit to be in. I was look most people and lazy with the auto.
  8. Jan 17, 2015 at 8:35 PM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    I had this happen in my ranger. 4 low and some throttle broke it free. I was in a bad mood that day. E brake never stuck again. It also never worked again.
    I set my ebrake a couple times a week to keep it "adjusted", seems like a good habit to get in. I rarely park on a hill so I just set it and release it a couple times a week2AR-FE*
  9. Jan 17, 2015 at 8:39 PM
    ivoryaddict
    ivoryaddict Well-Known Member
    Andy
    Northern California
    09 TRD offroad MGM DCSB
    Custom Headache Rack, BAMF Kick-out sliders with fill plate Level Kit, ARB bumper, Warn Winch Ruff Tuff Digital Camo Seat Covers Fuel 16" Boost Wheels Duratrac 285/75/16 X-tra D-Rings in Bed
    Snapped the e-brake line on my 1991 toyota, drove through a creek and then parked it overnight in freezing temps.
  10. Jan 17, 2015 at 8:44 PM
    jimbo808
    jimbo808 Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, 285/70r17 goodyear kevlar Mtrs, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, smittybilt X20 10k, pelfrey ifs skid, pelfrey trans skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
    I had this happen a few times after pressure washing after mudding. Just gotta stomp on the brakes really hard.
