06 Tacoma fuel filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by peleus21, Jun 12, 2009.
  1. Jun 12, 2009 at 5:17 PM
    peleus21
    peleus21 [OP] Well-Known Member
    okanogan, b.c. canada
    red trd sport
    led taillights HID dual beam headlights bolts and clamps to handle off road
    i off road quite a bit and have had my fuel cap and spout get wrecked. the cap will no longer stay tight and now i got enough dust in the tank that the screen on the pump is plugged.(it is the only fuel filter on the whole damn truck)
    toyota says that you have to buy a whole new fuel pump to get the screen and that it is not an individual part. can anyone help? is there an aftermarket deal a guy can find?
    the pump is 800 dollars!!!
  2. Jun 12, 2009 at 5:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The filter IS part of the pump....You should be able to find the pump cheaper than $800.00 though.
  3. Jun 12, 2009 at 5:32 PM
    peleus21
    red trd sport
    the filter is removable, held on by a bolt i believe was able to take it off and clean it even
    and so far noone even has a part number for a pump
  4. Jun 12, 2009 at 5:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Maybe you can find some similar material and make one?
  5. Jun 12, 2009 at 5:39 PM
    peleus21
    red trd sport
    maybe but it is not a sock like some of the other screens i have seen. it looks more like a power saw air filter. a screen glued to a housing. i would have to add a fuel filter in line if i make it from anything else just to be safe. this thing should have one anyways.
  6. Jun 12, 2009 at 5:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I agree.
  7. Jun 12, 2009 at 7:03 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
  8. Jun 12, 2009 at 8:11 PM
    peleus21
    red trd sport
    that is exactly what i need
    now if urd had a check out system that actually worked i could buy it
  9. Jun 12, 2009 at 8:52 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    How are you not getting a CEL with a loose gas cap??
    Marc M
  10. Jun 12, 2009 at 9:39 PM
    peleus21
    red trd sport
    i was i replaced the cap with a locking cap and replaced the filler tube and the new tube is just as bad. i know this must be a problem but toyota is not releasing a tsb on it but the new trucks come with proper screw type gas caps. my locking one can be taken off without unlocking it or even wiggling it.
    don;t get me wrong i love my truck but toyota is no better then ford for making stuff to break down and cost a fortune to fix. my next truck i am building from scratch and i bet it beats the pants off anything on the market for reliability, performance, and price
  11. Jun 12, 2009 at 9:52 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Keep us up to date on how well that works out for you...
  12. Jun 13, 2009 at 4:31 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    ok so i did a little research to prove the stealership wrong.
    all of this is direct from shoptrd.com
    i would paste a picture of all the system components which you can order separate but i'm having trouble with that.
    there are 2 pieces to the filler hose
    - "filler hose" the half that goes to the tank
    - "filler pipe" the half that goes to the fuel opening
    There is a fuel filter which is shaped like a canister, then there is a separate "filter" that looks like a cap thingy with a small tube coming down but you can't just order that piece.
    Filler Hose MSRP 37.44 Cost 27.46
    Filler Pipe MSRP 133.04 Cost 97.58
    Fuel Filter MSRP 53.02 Cost 38.88
    Fuel Cap MSRP 19.44 Cost 14.25
    Fuel Pump Assy MSRP 638.44 Cost 468.27
  13. Jun 13, 2009 at 9:34 PM
    peleus21
    red trd sport
    that is correct can't order the filter by itself real stupid.
    i completed my order with URD and am real excited to put it in and be back to full status
  14. Jun 13, 2009 at 11:50 PM
    johnecon2001
    Phoenix, AZ
    Can you do a write up if you do the work yourself? I will probably end up doing one of these eventually as well.
  15. Jun 14, 2009 at 3:24 PM
    peleus21
    red trd sport
    i sure can hope to have it up by next week. the downfall of the whole thing is that it is easier to do it by pulling the box of the truck off then dropping the tank. i will post both
