Iron Range Toyota Sucks!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by b2200srunnin, Nov 15, 2009.
  1. Nov 15, 2009 at 2:36 PM
    b2200srunnin
    b2200srunnin [OP] Pipeliner
    Dustin
    Columbus, MS
    09 4x4 trd pkg
    Foglight mod, Toytec Ultimate lift, Dakar leaf pack, Retros by Ant, led lights inside and out, URD TCAI/MAF sensor, Aero 2525 muffler, BFD 18x9 Matte Bronze wheels, Relentless Aluminum front bumper and steel rear bumper, 76mm Throttle body, '13+ mirrors with blinker lights, complete audio upgrade
    I got my oil changed at Iron Range toyota in Virginia, MN about 2 months ago. Today I washed my truck and somthing told me 2 pop the hood. When I opened her up I was shocked at wut I saw. There was oil all over everything on the drivers side of the engine bay. It took me a minute to find where it was coming from but the oil cap was off. It was sitting between the battery and the master fuse box. The dealerships service department must have forgoten to put it back on before they handed me the keys back. Ived done moved to a new town and since the oil change was so long ago probally cant get anything done about it anyway. I dont recommend that dealer to anyone
  2. Nov 15, 2009 at 2:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Good to hear. Perhaps a call to the service manager is in order?
  3. Nov 15, 2009 at 2:39 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I dont know but i think you wouldnt have a drop of oil left in your engine if it was like that for 2 months
  4. Nov 15, 2009 at 2:40 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Welcome to TW!
    Sorry to hear about that, yeah there is a lot of people on here that recommend and do they're own oil changes including myself.
    You should have called them up and had them clean out your engine compartment and get a refund on the oil change, that is a lot of BS that they did that, I would be mad as hell.
  5. Nov 15, 2009 at 2:41 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Wow that sucks! These are the reasons I dont take mine to a dealer to do anything there techs are normally sub par with my experiences having bought several new cars with the warranty packages there service techs seem clueless at dealers a lot of times. Subaru's were horrid let me tell you, I have not experienced toyotas nor do I want to but thats just a personal preference!
  6. Nov 15, 2009 at 2:42 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    you didnt pop the hood for 2 months??!! i check my oil and inspect the engine bay at least every fill up....
  7. Nov 15, 2009 at 2:43 PM
    Hoyal
    Devin
    2013 Tundra
    Really? That seems a little extensive.. Im sure I have gone 2 months before popping my hood at some point in my driving life...
  8. Nov 15, 2009 at 2:44 PM
    Yoytoda
    Roland
    completely stock
    did you ever smell oil burning? but agreed bottom line is either they didnt put it back on or didnt tighten it. Either way they arent going to do anything for you...BASTARDS!!! another dealer screwing another customer.
  9. Nov 15, 2009 at 2:46 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    really...for reasons just like this, it would only have been 350 miles MAX until i would have caught this problem. what if the OP never did pop the hood that day, lost all the oil, then seized the engine?! its always good to know that my vital fluids are good to go for my machine!
  10. Nov 15, 2009 at 2:48 PM
    Hoyal
    Devin
    2013 Tundra
    For sure no argument here but every fill up is kinda a lot well at least for me I would be popping the hood 2 to 3 times a week just with fill ups lol. I wheel a good bit and check it before those trips or longer than normal driving times.
  11. Nov 15, 2009 at 2:51 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    ^ yea, well i only fill up once a week, and have nothing else to do while i wait for the gas to pump, so i check my engine!
  12. Nov 15, 2009 at 2:58 PM
    OffroadToy
    Wow, hard to believe you didn't notice a smell or smoke. Did any oil show on the dip stick?
  13. Nov 15, 2009 at 2:59 PM
    hardattack
    hardattack Member
    Kevin
    Virginia
    04 tacoma trd 4wd manual
    I am sorry that that happend to you. But I am sure it was a mistake no one would have done that on purpose. Everyone makes mistakes. Thats why they tie the gas cap on to the gas door with a string now. You ever accidentally left the gas cap off after filling the tank? Maybe not. But so many people have they now tie it on;)
  14. Nov 15, 2009 at 3:01 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yea that sucks hopefully your truck didnt run too long with out oil
  15. Nov 15, 2009 at 3:05 PM
    b2200srunnin
    Dustin
    Columbus, MS
    09 4x4 trd pkg
    never smelt oil burning or anything as far as that goes. most of the oil was on the bottom of the hood and on the break fluid resivor. hardly any oil on the lower fender well.
    as far as changing my own oil hassle foe me to keep everything need for an oil change and I dont always have a place to change it at. I move about every 3-4 months going from job to job. dearlerships are convenient for me. my dealership where i bought it from is excellent and i know the people that work there
  16. Nov 15, 2009 at 3:59 PM
    Yoytoda
    Roland
    completely stock
    All i keep is a filter wrench and a drain pan and use a 14mm(i think) which is included in any basic tools. To me its actually more convenient. Id rather spend 10mins changing my oil then 45mins waiting for someone else to do it. my .02
  17. Nov 15, 2009 at 10:12 PM
    nharkey85
    nharkey85 2yr Old Co-Pilot
    Neil
    Alabama
    08 D-Cab TRD OffRoad
    3" Rev-Tek Lift, N-Fab steps, Aux. Rev. lights, DTRL, Fog light mod
    yet you wouldn't believe how many vehicles i see with the cap hanging out of the filler door.
    on point...yea it is more convenient to take it to a dealership in the OP's case. I just crossed 20K in my rig, probably wont see the dealership again just for oil changes
  18. Nov 16, 2009 at 7:12 AM
    jonny
    jonny Betty White Edition Heep ZJ
    John
    quoted for troof
  19. Nov 16, 2009 at 7:29 AM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    Which is when the CEL comes on. Gotta double-idiotproof & reverse-idiotproof everything these days. Lots of attention defecit running rampant. Pandemic even. Gotta stay super vigilent to minimize it's possible occurrence in everything you do that has any other people involved FTW...........
  20. Nov 16, 2009 at 7:42 AM
    coldcanuk
    coldcanuk Well-Known Member
    Calgary
    3.4 L
    Takes me longer than 10 minutes but I agree. The dealerships here are over $100/hr labour and the oil changes are done by 16 year old kids.......
    I just wish they'd placed the oil filter in a similar location to the FJ. Everytime I see the FJ oil filter location, I think it's genius. Nothing like a Gen1 oil filter that's been tightened to death and trying to get it off.
