Difference between SR5 suspension and TRD suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by carletos, Dec 6, 2009.
  1. Dec 6, 2009 at 5:25 PM
    carletos
    carletos [OP] Member
    Victoria TX
    09 PreRunner Regular Clean Slate
    Weathertechs, rear TSB, Eibachs, 1/2"spacers,5100s
    After reading the plethora of info that is available on the site I am left with one main question. What is the difference between the SR5 coils that are on my 09 regular cab prerunner and the TRD coils? The reason I ask is because I would like to emulate the TRD ride of my friend's tacoma. Should I just purchase the coils or is the better option. Any help would be appreciated. This is also my first post so let me know if I made any newbie mistakes.
  2. Dec 6, 2009 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    SR5 and TRD Sport use a non progressive rate spring, while the TRD Off Road uses a Progressive rate spring.
  3. Dec 6, 2009 at 5:28 PM
    carletos
    Victoria TX
    So should I just go to the dealership and order TRD off-road coils, or is there a better aftermarket choice?
  4. Dec 6, 2009 at 5:28 PM
    NotstockTRD
    NotstockTRD TRD
    st louis
    99 TRD Prerunner V6 with many mods..
    Shitloads
    sr5 indicates chrome package I thought?
  5. Dec 6, 2009 at 5:31 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    SR5 is an interior package more than a suspension thing- I think he means the base suspension.
    And there are much better options in aftermarket purchases- OME, Bilstien both make shocks, OME also makes coils...as does eibach and a few others.
  6. Dec 6, 2009 at 5:34 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    If your going to buy new coils you might as well get some that give you a little lift. Heard good things about these:
  7. Dec 6, 2009 at 5:39 PM
    carletos
    Victoria TX
    If I already picked up some stock trd bilstein shocks, can I use them with eibach coil lift? Thanks for all the help.
  8. Dec 6, 2009 at 5:40 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I think you can...but you are better off getting shocks made to be used with a lift kit....The TRD coils are not built to be lifted.
  9. Dec 6, 2009 at 6:40 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Also remember the TRD Off Road has a smaller sway bar to go with the progressive coils, your PreRunner has the TRD Sport coils and sway bar (which is bigger). To avoid a mismatch in your suspension set up, you should just get the TRD shocks.
  10. Dec 6, 2009 at 6:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Off Road, and SR5 have the same sway bar, but the TRD Sport has a larger diameter.
  11. Dec 13, 2009 at 12:13 PM
    canuck_tacoma
    canuck_tacoma Well-Known Member
    BC, Canada
    SR5 4X4 Tacoma Access Cab
    1.5" Eibach Front Coil Lift, Rear TSB, 265/75/16 BFG A/T's
    I am running the Eibach coils with stock TRD shocks. On road it is great, if you are going to do serious of road with large compressions then a 5100 would be a better shock. Myself, I only do service roads and the odd rough road so I don't feel the need to change out my TRD's. I do find the odd large bump it would be nice to have more dampening.
  12. Sep 5, 2014 at 12:14 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    I have a 07 Prerruner double cab with SR5 package (no TRD). What size in mm is my swaybar?
