09 Dbl Cab 4x4 rear lift w airbag? Heavy load, leveling.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMO, Jan 18, 2010.
  1. Jan 18, 2010 at 4:22 PM
    TacoMO
    TacoMO [OP] Well-Known Member
    Jeff
    fly over zone
    09 dbl cab 4x4 TRD Off Road
    Shell
    I know I have the terms wrong, but I am looking for a rear adjustable airbag for leveling the load.
    Maybe I have this all wrong, but I am going to haul a fairly heavy (400 lb) motorcycle on a hitch mounted carrier. I have used it several times in the past for short trips with no problem.
    I have a 1,000 mile trip planned for next month. (each way.)
    Is there some type of lift or air controlled ride height adjusting device that is available?
    I don't think it's good for the truck to ride with the back end sagging for 2,000 miles..
    If anyone has a suggestion, I'd appreciate it.
    Thanks,
    Jeff
  2. Jan 18, 2010 at 6:01 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Have you had the rear leaf TSB performed? I would look into this before investing in an airbag system when the TSB would be performed under warranty and would only cost you your time.
    I wouldn't be too concerned with hauling the Harley especially after having the TSB done.
  3. Jan 18, 2010 at 6:07 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    i haul 2 dirtbikes roughly 525 pounds with 100 pounds of gear all over the place and i really dont sag. One time i did bottem out, but i was going close to 100 in a 45 zone:facepalm:. other then that i go about 300 miles on riding trips and i really dont see a problem, other then i cant burn out with them in there:D(even brake starting)
  4. Jan 18, 2010 at 6:30 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    x's 2 on the TSB...
    I had the TSB done on my '09, and I haul my ATV with no issues, even offroad...
  5. Jan 18, 2010 at 7:48 PM
    slooowr6
    slooowr6 Member
    Take a look at Firestone Ride-Rite air bags, http://www.fsip.com/riderite/ . Easy to install and reasonable priced. I tried Air-Lift, the placement of the bag is not idea for really heavy load (1000lbs) in truck bed.
