-   -   2nd Gen Tips, Mods & More (http://www.tacomaworld.com/forum/2nd-gen-tacomas/7174-2nd-gen-tips-mods-more.html)
tcBob 03-26-2008 10:52 PM
Note: this post is a compilation of things that would otherwise be stickied in the 2nd gen thread. If you're looking for a thorough list of mods, check out the Tacoma mods (1st and 2nd gen) thread maintained by piercedtiger.
TSBs
2010 Transmission TSB
2009 Transmission TSB
Check here for a list of all the available TSBs
Check here to see if anyone has had the Suspension TSB performed in your area and what their experience was.
Common Problems
-Steering Wheel Shake
-Steering Wheel Shake 2
-Steering Vibration Fix
-Blower Motor Squeek Chirp Low Fix
-Fan Speed Switch Not Working
-Overhead Console Temp/Compass Fix
-Squeaky Leaf Fix
-DIY Fix your ticking engine
Maintenance Tutorials
-Remove CV Axle and Replace Front Wheel Bearing
-Front Diff Transfer Case Oil Change
-Reset Maintenance Required Light
-Cleaning the throttle body
-Full Automatic Transmission Flush
-Replace shifter indicator lamp
-How to change tail lights
-How to change third brake light
-How to Drain/Refill Automatic Transmission
-DIY Full Flush Automatic Transmission
-DIY Front Brake Pad Change
-UCAs Alignment
-How to remove/install 1GR-FE alternator
-Transfer Case oil change
-Inside 05 Transfer Case
Modifications
-Installation and Removal of E-Locker 3rd Member
-Daytime Running Lights
-Sleeved fog light housing
-Install Homelink Garage Opener
-DIY Tailgate Lock
-DIY Tailgate Lock 2 (advanced)
-Installing side steps
-Heated Mirrors
-DIY Washable Cabin Air Filter
-Tinting your tail lights
-Installing a Toytec Lift Kit
-Installing a Toytec Differential Drop
-Leather Arm Rests
-Non-OEM Foglights
-Illuminated 4wd Switch
-Secure Locking Gas Cap
-Lights under the hood
-Differential Breather Mod for Dummies by Neubs
-Bed Mat Mod
-Program OEM Wireless Remote
-How to wire bed lights
-Satoshi Grill Mod write-up
-Beep on lock
-Cheap Vehicle Tracking System
-Remove/Replace Door Handles
-USB Power Plug
-Installing running boards
-Pop N Lock install
-How to Trim Mud Flaps
-Installing HID lights
-Remove Center Console
-Oil Pan Heater Mod
-Long Travel Information
-Lifting Your Truck - Things you need to know
-Change LEDs in the stock radio
-Backlit Toyota Grill
-Inexpensive Mirror Mount for GPS, Radar Detector, etc.
-Headlight Removal
About Your Truck
-List of sockets and wrenches for 2nd Gen Tacoma
-Disable the Antilock Braking System (ABS)
-Every Part # for your Ride
-Toyota TRD Catalog
-Drive Modes - Traction Control
-1GR Info
Show us your...
-Taco
-Taco - Take 2
-Stereo
-Stickers
-Wet Okoles
-Shell
-Bumpers
-Sliders
Show us your Cab Styles
-Double Cab Long Bed
-Double Cab Long Bed - Take 2
-Double Cab Short Bed
-Access Cab
Show us your Colors
-Indigo Ink
-Magnetic Grey Metallic
-Timberland Mica
-Pyrite Mica
-Super White
-Barcelona Red Metallic
-Black Sand Pearl
-Silver Streak Mica
-Speedway Blue
-Radiant Red
-Impulse Red
-Desert Sand
-Blue Ribbon Metallic
-Spruce Mica
-Silver Sky Metallic
lsocoee 02-24-2010 10:08 AM
I opened this thread for link suggestions.
Simon2150 02-25-2010 06:32 AM
Originally Posted by lrgrnr (Post 1469512)
What about the sticky for the Taco colors??? Or a link???
It's there, 7th one from the bottom going up.
Mark C. 02-25-2010 06:52 AM
Is there one for the "Backup Camera Anytime" "Switched Backup Camera" Mod?
lsocoee 02-25-2010 10:36 AM
you can check the cheap tacoma mods thread, if it isn't there then you can provide me a link.
Mark C. 02-25-2010 12:05 PM
Here's the link for the backup camera always on thingie.....
http://www.tacomaworld.com/forum/2nd...ew-camera.html
lsocoee 03-01-2010 05:44 PM
I added some photo threads. Does anyone else have any favorite photo threads?
dog tired 03-07-2010 06:23 PM
3 Attachment(s)
Bed rack
link
http://www.tacomaworld.com/forum/2nd...-bed-bars.html
jmg256 03-09-2010 07:49 PM
DIY Front brakes or brakes in general?
Fixed...
http://www.tacomaworld.com/forum/2nd-gen-tacomas/38025-diy-front-brake-pad-change.html
and
http://www.tacomaworld.com/forum/whe...or-change.html
dog tired 03-10-2010 04:36 AM
link
cable lock anti theft tailgate mod
http://www.tacomaworld.com/forum/2nd...ml#post1523358
kinkrider101 03-23-2010 06:10 PM
265/70/16 rub with 3'' lift!!!!
my tires wub the front plastic when reversing. whats up with that?
i just added spidertrax spacers also
06dak 03-28-2010 09:33 AM
Link to the 30k maintenance for 4cyl models...
http://www.tacomaworld.com/forum/4-c...intenance.html
Kelson 04-01-2010 12:21 AM
a regular cab one?
like this one?
http://www.tacomaworld.com/forum/2nd...ular-cabs.html
Janster 04-01-2010 08:16 AM
Heated seat install
http://www.lieblweb.com/heatedseat.html
btkicker 04-01-2010 09:57 AM
The 4low+TRAC mod:
http://www.tacomaworld.com/forum/technical-chat/51946-4low-trac.html
It's a no-brainer.
justinhemler 04-17-2010 08:55 AM
i just need to find where to order 09 factory fog lights.... any help?
Peanut424 04-22-2010 11:59 AM
which way to go?
I got a little over $300 for my birthday, I want to go with a spacer lift for the yota but some people say if I lift it than I should do it right and do UCA and coils and yada yada. But seeing as how I'm impatient and don't want to keep saving money. Which way should I go? Cold air intake, exhaust, other mods. I'm clueless.
Tacoma2010530 05-03-2010 06:11 AM
Alarm Issues
I have a 2010 Tacoma with the factory VSP alarm. It like to go off for no reason. Has anyone heard of this or know why? I know it is a 2010 and it is under warranty, however I like to do a little research before going to the dealer.
Thanks,
Evil Monkey 05-07-2010 07:48 AM
Suggestions:
How to use the search function
3" Lift - Show your taco
6" Lifts or more
Photoshop request thread
Jimmyjohn 05-14-2010 01:31 PM
I just ordered a set of Piaa 525 driving lights to go on my Smitty Bilt Bull Bar. they will be here next week.
