disabled door buzzer & seatbelt alarm.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KTMRacer, Feb 21, 2010.
  1. Feb 21, 2010 at 1:28 AM
    KTMRacer
    KTMRacer [OP] Member
    Richard
    Silverdale, Washington
    09 SR5 TRD 4x4
    rock chip
    Hi, I am new to tacoma world this is my 1st post. Can anyone provide me with info on how to disabled the door buzzer, along with the seatbelt alarm on my 2009 Tacoma? Thanks in advance for your assistance. Rich
  2. Feb 21, 2010 at 1:30 AM
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
    Welcome to TW. Don't have the coding for the door, but here is the coding I have...seat belt and the keyless entry:
    Seat Belt Chime
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
    No beap
    Last Modified: 5-14-20085.1 DFrom: 200805Model Year: 2009Model: TacomaDoc ID: RM000000XXC01SXTitle: DOOR LOCK: WIRELESS DOOR LOCK CONTROL SYSTEM: CUSTOMIZE PARAMETERS (2009 Tacoma)
    1. CUSTOMIZING FUNCTION
    The following items can be customized.
    NOTICE:
    When the customer requests a change in a function, first make sure that the function can be customized.
    Record the current settings before customizing.
    When troubleshooting a function, first make sure that the function is set to the default setting.
    If the battery is disconnected, the wireless answer-back buzzer will be returned to the default setting.
    Item
    Function
    Default Setting
    Customized Setting
    Wireless remote control
    Operation signal (Buzzer)
    ON
    OFF
    (a) Open the driver side door and insert the key into the ignition cylinder.
    (b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON.
    (c) After 10 seconds, the system enters answer-back buzzer switching mode.
    (d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice, the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
    HINT:
    The driver side door is closed.
    The ignition switch is turned off.
    The key is removed from the ignition cylinder.
    A transmitter button is not pressed for 10 seconds after answer-back switching mode is started.
    The transmitter is operated but the second button pressed is different from the first.
    Answer-back starts.
    sawx75 likes this.
  3. Feb 21, 2010 at 2:48 AM
    KTMRacer
    Richard
    09 SR5 TRD 4x4
    rock chip
    Thanks for such a fast reply. I will give it a shot in the morning.
    Regards,
    Rich
  4. Feb 21, 2010 at 2:58 AM
    KTMRacer
    Richard
    09 SR5 TRD 4x4
    rock chip
    Sometimes I would like to have my truck doors open listening to my stereo not the door chime. Anyone know how to disable the door chime?
    Thanks,
    Rich
  5. Feb 21, 2010 at 3:30 AM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    This work for the 2010 ?
  6. Feb 21, 2010 at 10:22 AM
    mountain lion
    mountain lion Member
    VA
    06 PreRunner
    URD TCAI, MAF Cal, o2 Sim, DT Headers
    Couldn't get the seat belt trick to work on my 06... :( The odo never changed after putting the seat belt in.
  7. Feb 21, 2010 at 10:23 AM
    FL Forester
    FL Forester Well-Known Member
    Jason
    Tallahassee, FL
    2016 4Runner
    Doesn't work for the 06
  8. Feb 21, 2010 at 10:26 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    I believe the door chime goes away if your key is in the ON position.
  9. Feb 21, 2010 at 10:28 AM
    ColdZeroBSP
    ColdZeroBSP Yo homie, that my briefcase?
    Geoff
    Tewksbury MA
    2012 TRD Sport DC
    console vault, viper remote start, weathertech front and rears
    If you mean the seat belt chime then yes. Did it on mine a few weeks ago. Good thing too cuz I was about to start cutting wires....:annoyed:
  10. Feb 21, 2010 at 10:34 AM
    FL Forester
    Jason
    Tallahassee, FL
    2016 4Runner
    I think the only way to disable the door chime it to remove the speaker in the dash.
  11. Feb 21, 2010 at 10:54 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    Is you seat belt chime 100% off? Mine still chimes for ~ 5 seconds before it turns off.
  12. Feb 21, 2010 at 11:11 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    thats because the 05-07 doesnt have the seat belt beep. its only on the 08-10
  13. Feb 21, 2010 at 11:17 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    If you're outside the truck roll the window down :D
  14. Feb 21, 2010 at 11:55 AM
    KTMRacer
    Richard
    09 SR5 TRD 4x4
    rock chip
    Anyone know where the speaker is located in the dash?
  15. Feb 21, 2010 at 12:03 PM
    rossk35
    hawaii
    its on the instrument cluster.
  16. Feb 21, 2010 at 12:22 PM
    Carlo
    Carlo Well-Known Member
    CA
    2010 Taco Magnetic Grey
    5100's all around, front at 0 with Ebiach springs up front; Wheelers 3 leaf AAL rear, Spidertrax
    Singlefin: Thanks a bunch...it was driving me nuts on my new 2010 when the dog would jump in the truck with me. I followed your directions and it was a snap. Should this be a sticky?
  17. Feb 21, 2010 at 12:55 PM
    singlefin
    Hood River, OR
    Syncro
    yep, worked in my 2010 and the OP's truck.
    No worries, had it saved as a email draft so it was handy.
  18. Feb 21, 2010 at 7:23 PM
    KTMRacer
    Richard
    09 SR5 TRD 4x4
    rock chip
    That worked great! Thanks.
    Now if I could just figure out how to disable to door chime.
  19. Feb 21, 2010 at 7:33 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    door chime ..I just cut into the wire and wired in a toggle on my dash. this way i can use it when i want and not use it when i dont:)
  20. Feb 21, 2010 at 8:41 PM
    KTMRacer
    Richard
    09 SR5 TRD 4x4
    rock chip
    Which wire? Can you provide more info?
    Thanks,
    Rich
