Ultimate HID retrofit!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yosh2000, Apr 2, 2010.
  1. Apr 2, 2010 at 8:02 PM
    yosh2000
    yosh2000 [OP] Well-Known Member
    CO
    '17 Tundra CM 5.7
    06/20/10 UPDATE AT BOTTOM
    well, finally started on my much anticipated FX-R retro with level motors...!! i know, i know, its going to take me awhile to finish them too, but i decided to document some stuff just in case you guys want to try it as well.
    here is a link to the thread that gave me the idea to do this. all the electronic wiring is exactly the same, as i tested it today.
    first off, ordered an OEM level switch from a 04-09 toyota sienna XLE version ONLY (as this is the only model that comes w/ HIDs from my understanding)! this switch (PN 84152-33030) will fit and matches our slots perfectly.
    here are some pics of the level motor. dont know the PN, but its from 2003+ celicas w/ HID headlights, and most likely other toyota/lexus vehicles w/ HIDs as well.
    here are some pics of the level motor completely retracted and completely extended. i get about 0.156" of travel. did some math, and even w/ my bed loaded w/ 1600#, i will still be able to level out my headlights!!
    05/15/10 UPDATE
    test fitted the motors today. here is a vid showing the reflector (and therefore the projector when mounted) moving ever so slightly. this movement will raise/lower the cutoff. vids of this can be found on youtube now, and i will post my actual one when completed.
    http://www.youtube.com/watch?v=RFaYiVVUPpQ
    06/20/10 UPDATE
    been busy doing retros for two other guys, so finally got to get back to this one...
    the following series of shots is how i mounted the motors. i used that two part epoxy putty stuff to fill in and give a more solid mounting surface...enjoy! im aiming to finish this thing by next weekend as a i have a roadtrip to CO and it sure would be nice to have these lights installed before them....so check back often!
    DistortedAxis likes this.
  2. Apr 2, 2010 at 8:08 PM
    TaComatoseSR5
    TaComatoseSR5 Mud Junkie
    Stephen
    Tampa, FL
    White 05' SR5 Access Cab 3" lift
    3" Toytec lift (coils and aal), 285/75/16 terra grapplers, HID conversions,led taillights, grillcraft grill, on board air with air horn
    WOW! now thats kind of sweet
  3. Apr 2, 2010 at 11:50 PM
    memario1214
    Colton
    Missoula, MT
    Nice! Subscribed
  4. Apr 3, 2010 at 8:12 AM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    I will be very interested in seeing out this turns out...I would like to know how the level motors are going to be mounted to the headlights
  5. Apr 3, 2010 at 8:22 AM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Jason
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Aww, I thought this would be a quad bixenon setup, but this is even better!
  6. Apr 3, 2010 at 9:30 AM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    cool, but almost seems like all that work for minimal gain.
    Now you're going to have to hack up the plastic housing and mount this device. Run extra wires and shit. More things to go wrong.. :eek:
    To me, it would be easier to just use a screwdriver for about 30 secs if i had to adjust the elevation of the cutoff.
  7. Apr 3, 2010 at 9:52 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
  8. Apr 3, 2010 at 10:11 AM
    yosh2000
    CO
    '17 Tundra CM 5.7
    yea but your missing the entire point...how many 05+ tacos have a HID retrofit w/ a cockpit on the fly level switch..;) i could adjust w/ a screwdriver, but i would not be able to achieve replication of my cutoffs.
    what can i say, im an engineer, i live for geek stuff like this!
    G.T. likes this.
  9. Apr 3, 2010 at 10:22 AM
    krisjw101
    krisjw101 Well-Known Member
    Kris
    Spokane,WA
    09 Tacoma 4x4
    Autobot in my rear window
    Sounds like it will be awesome!!
  10. Apr 3, 2010 at 10:24 AM
    The End
    The End Support our troops!
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Impressive, subscribed.
  11. Apr 3, 2010 at 10:38 AM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
  12. Apr 3, 2010 at 3:53 PM
    Wolfman
    Wolfman Well-Known Member
    Paradise, TX
    2010 PreRunner SR5
    I'll be watching this one as well.
  13. Apr 3, 2010 at 4:23 PM
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    Sweet! How about a group buy!! :D jk! This is going to be sweet! Can't wait to see how it turns out!
  14. May 15, 2010 at 7:46 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    bump for update! going to start tearing apart my smoked 09+ lights tonight!
  15. May 15, 2010 at 7:51 PM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Ooh, very nice!
  16. May 15, 2010 at 8:58 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    That's awesome! How'd you mount the motor? Got a pic?
  17. May 15, 2010 at 9:44 PM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    OMFG! I just finished PM'ing you about my Retros. I thought I was all happy and excited until I opened this Bull Shit up. Thanks Jackass. Now you've got me drooling all over this shit. YOu've just got to tinker and be creative now. Fantastic.
    Tell me kind sir, how much more is it to get the switch, the parts, and labor to step my Once Happy Retros up? Huh? Jerk.
    Looks like I'll be looking into this now. You can never be just satisfied.
    Note to self. Don't open up any threads that has to do with Lights & Yosh.
  18. May 15, 2010 at 10:00 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    :annoyed:
    So how much for an upgrade, cough cough. Dang you Josh. Looks good and I'm still loving my retros, thanks again.
  19. May 15, 2010 at 10:04 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    ^ what can i say ray, i aim to please. and most of my mods i dont mind doing for people for the right price for my time...but this ones for me and me alone! i can help out in any way i can for PNs, ideas, and pics, but my this is a therapeutic for me to handle all the crap that has been going on in my life...!!
    i removed the lower screw mount, then enlarged it to 13/16, cut three notches for it to pass thru and turned. it was just a mock up on a busted set of egay lights to see if it would all work. now that it has, i'll get a nice, clean, and sturdy mounting of the motors and post some pics when i do.
  20. May 15, 2010 at 10:06 PM
    RAD
    Rad
    LAX & LOGAN
    ^Yep Ty. . .
    I was going to tackle the Retros but as they sit all pretty in the original box. My dirt bike has taken so much of my time now. Learning to work on it, ride, and mod it has consumed me.
    I even thought of selling my Retro kit to fund my Bike. :(
    However, Yosh's work is amazing and I freaking need Spindles now.
    I sit and dwell on yours, Amirs, & Yosh's Spindled Tacos. Then you and Yosh have Retros. . . AGGGGGGH.
    Sometimes I had this forum as I would've never done so much to my truck. I'd be a happy normal stock Taco with a lot more $$$$ & time. :p
