-   -   Transmission just started lagging after 55K... (http://www.tacomaworld.com/forum/2nd-gen-tacomas/90340-transmission-just-started-lagging-after-55k.html)
Kenny650 05-01-2010 11:19 PM
I've searched this and it seems as though only the newer Tacomas are getting a tranny lag. Mine just started lagging ever since I hit 55,000 on the odometer - WTF.
I slow down and when I accelerate again it takes a bit for it to kick into gear. Is this the so called transmission lag?
BakoTruck 05-01-2010 11:31 PM
What do you mean by "kick into gear"? Are you talking about it taking longer to shift, or it is very slow to get up to speed?
I notice that my truck does some weird stuff with shifting from time to time, you could try taking it in to get the trans flashed.
Kenny650 05-01-2010 11:45 PM
It's taking longer than usual to shift. It revs up pretty high then kicks into gear and lurches forward. It's getting annoying.
BakoTruck 05-01-2010 11:52 PM
Don't know what to tell you, could be a problem with the torque converter, or the trans. All I can recommend is getting the trans flashed, and also doing trans oil change, since you are getting close to the recommend time to change. 60,000-70,000 miles I believe is the recommend time from Toyota.
Sorry I wasn't much help, but hopefully someone else has some ideas to add on what it could be.
Fortech 05-02-2010 05:10 AM
I would try a drain and fill of the pan. At least once completed you will know the ATF level is at the correct level.
