gonna get firestone ride rite kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by l_prettyman, May 3, 2010.
  1. May 3, 2010 at 2:27 PM
    l_prettyman
    l_prettyman [OP] Well-Known Member
    Logan
    Maryland
    18 TRD Offroad
    my question is how will it look getting a 3 inch lift kit on top of getting these bags? i would get the block kit for the rear since adding a leaf would make the ride way too stiff with bags. so anyone running this setup or have any input?
  2. May 3, 2010 at 5:00 PM
    soilsample
    soilsample Well-Known Member
    Donald
    Southwest Louisiana
    '19 TRD Off Road
    I have an AAL lift in rear with firestone airbags. My front is lifted with Toytec ultimate lift.
    The bags only add lift to the rear with About 10 lbs or more of air pressure. I run about 3-5 lbs with no load which won't give much lift if any at all.
    If you run 10+ without a load, your shocks won't do anything.... Only riding on a very stiff air bag which made my truck buck like a mad bronco!!!
    So what I'm saying is don't count on using the air bags to achieve much lift.... Only to prevent sag.
    Donald
  3. May 4, 2010 at 6:22 PM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
    thanks, how high is your lift and can you post pictures of your whole setup?
