-   -   Running a 4gauge Amp Kit in a 2nd Gen Taco (http://www.tacomaworld.com/forum/2nd-gen-tacomas/9668-running-4gauge-amp-kit-2nd-gen-taco.html)
Osiris117 05-31-2008 07:23 AM
Hey Guys,
This is a reply to an earlier post of mine. I was having some trouble running my Amp kit in my 2008 Taco, however last night I had a few revelations.
First, there is a large rubber gromet on the driver-side of the firewall where the wiring harness from the underhood fusebox runs inside the truck, on the bottom side of this is a small nipple:D. This is for running wires for various other goodies, clip the end off and with a friend, a piece of wire and a healthy dose of dish soap you should be able to get ur 4ga wire through it with out a problem.
Second, there are several places to ground your kit, but the best place is a small bolt located under the rear storage area under the rear seat, remove this plastic tub abd look right next to the lock bar for the passenger-side rear seat, it holds a bracket for the seat frame it should be a small silver 11mm bolt, remove this ground your kit to this, the drill a small hole in the black pastic cover to run your ground to your amp, look for pictures later.
Hope that this hels anyone that needed help.
- Matt (Osiris117)
