5 speed hard to go into reverse
Old 11-02-2010, 12:25 PM   #1
Quick_1911 [OP] Quick_1911 is offline
Quick_1911 is on a distinguished road
Quick_1911's Avatar
Quick_1911's Tacoma Gallery
Any of yall ever have problems going into reverse with your 4 cyl 5 speed trucks? Mine does it every once and a while and seems like it will go about haflway into the reverse slot but not all the way and it goes in once I row thru the gears once it goes in fine. This a common thing or should I be worried? Thanks
Old 11-02-2010, 12:27 PM   #2
braaap
steve o 77's Avatar
steve o 77's Tacoma Gallery
Normal. It's because reverse does not have a syncro and are straight cut so the gears can sometimes not be lined up right. When mine does it I just put it in neutral, release the clutch for a sec and try again, it always goes in after that. FYI mine doesn't grind, just seems like its hitting a wall.
Old 11-02-2010, 12:29 PM   #3
Quick_1911's Avatar
Ok good to know, Thanks man. On mine its like it gets halfway in and it'll catch like it hits a wall.
Old 11-02-2010, 12:32 PM   #4
braaap
steve o 77's Avatar
Yup, exactly what mine does.
Old 11-02-2010, 12:32 PM   #5
Almost there
08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed
08pretaco's Avatar
08pretaco's Tacoma Gallery
Mine goes into reverse much easier once I take it into first then go directly to reverse.
Old 11-02-2010, 12:38 PM   #7
Quick_1911's Avatar
Originally Posted by numbah57 View Post
My URD ss cleaned that up a little bit.
How hard was the install with the ss? Did you have to do any cutting/grinding?
Old 11-02-2010, 12:43 PM   #8
BORN AND RAISED MAUI BOY
numbah57 is one of the sharper tools in the shednumbah57 is one of the sharper tools in the shednumbah57 is one of the sharper tools in the shednumbah57 is one of the sharper tools in the shednumbah57 is one of the sharper tools in the shednumbah57 is one of the sharper tools in the shednumbah57 is one of the sharper tools in the shednumbah57 is one of the sharper tools in the shednumbah57 is one of the sharper tools in the shednumbah57 is one of the sharper tools in the shednumbah57 is one of the sharper tools in the shed
numbah57's Avatar
numbah57's Tacoma Gallery
No cutting or grinding but I did have to bend up the ahem metal around the shifter a little, nothing to bad, the rest of the install is super easy.
Old 11-02-2010, 12:44 PM   #9
numbah57's Avatar
Sorry about the miss spell (damn touch screen) it's the sheet metal I had to bend.
Old 11-02-2010, 11:45 PM   #11
sachou is one of the sharper tools in the shedsachou is one of the sharper tools in the shedsachou is one of the sharper tools in the shedsachou is one of the sharper tools in the shedsachou is one of the sharper tools in the shedsachou is one of the sharper tools in the shedsachou is one of the sharper tools in the shedsachou is one of the sharper tools in the shedsachou is one of the sharper tools in the shedsachou is one of the sharper tools in the shedsachou is one of the sharper tools in the shed
sachou's Avatar
sachou's Tacoma Gallery
Yeah, what they said. Line up the gears. Most likely you're parked on just enough of a slope to move the truck the 1mm it needs to line up gears. Sometimes you'll have to go into first and inch the truck forward to get it to line up.
Hell, most of the time, I kind of just like kind of sit down violently/rock the vehicle back/forth. That's usually enough movement to get it into reverse.
Old 11-03-2010, 12:10 AM   #12
S.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shed
S.B.'s Avatar
S.B.'s Tacoma Gallery
Originally Posted by 08WhiteTaco View Post
Shift to first then to reverse, helps line up the gears better...
^^^^This. It is common practice thing to shift into first then into reverse on manual transmissions. It lines up the gears since the reverse does not have a syncrod.
Old 11-03-2010, 08:36 PM   #13
Thread Jacker
schiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shed
schiz94's Avatar
schiz94's Tacoma Gallery
i do this. btw... never be rolling when you put it in reverse. it grinds... trust me
Old 11-03-2010, 08:52 PM   #14
nagelg is a glorious beacon of lightnagelg is a glorious beacon of lightnagelg is a glorious beacon of lightnagelg is a glorious beacon of lightnagelg is a glorious beacon of lightnagelg is a glorious beacon of light
nagelg's Avatar
Army: 173rd Airborne, Pathfinder, MACV
nagelg's Tacoma Gallery
Send a message via Yahoo to nagelg
It's called 'double clutching' Years ago you had to do it on most of the stick trans to make them go into reverse.
Old 11-03-2010, 09:21 PM   #15
MowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shed
MowTaco's Avatar
MowTaco's Tacoma Gallery
Mine does it too... I just "double clutch" it.
Now that we have that resolved... why does reverse grind if you're moving slightly? I can shift into 1st while rolling forward or backward and it's fine, but if I'm not at a dead stop to go into R then its clunkgrrgrrrrgrrgrrrgrrrr
Old 11-03-2010, 09:41 PM   #16
braaap
steve o 77's Avatar
No syncro on the reverse gear.
Old 11-03-2010, 10:03 PM   #17
Thread Jacker
schiz94's Avatar
Hahahahahaha
Old 11-03-2010, 10:23 PM   #18
braaap
steve o 77's Avatar
Originally Posted by schiz94 View Post
Hahahahahaha
whats so funny?
Old 11-03-2010, 10:29 PM   #19
Thread Jacker
schiz94's Avatar
It seems like you said reverse doesn't have a synchro like 20 times. I guess not
whats so funny?
Old 11-03-2010, 10:34 PM   #20
S.B.'s Avatar
ya theres no syncro for reverse.
purple/white = reverse gear signal pink = Car Speed Sensor STxTaco Audio & Video 7 01-06-2012 05:21 AM
Loud clank during hard braking & speed bumps CruJones33 2nd Gen. Tacomas 3 06-21-2011 05:52 PM
6-Speed Reverse "Beep" Gone...Any ideas? Jay238 2nd Gen. Tacomas 10 10-26-2010 09:56 PM
Sometimes hard to get in reverse JoeBama 2nd Gen. Tacomas 19 06-12-2010 08:01 AM
Very low speed shudder in drive but not reverse jimmyfix 1st Gen. Tacomas 2 11-13-2009 06:34 PM
