2006 when starting engine goes to 2000rpm
Old 11-09-2010, 06:58 PM   #1
buckstaco [OP] buckstaco is offline
buckstaco is on a distinguished road
Army: sp HQ 8th army Ord 62/63
buckstaco's Tacoma Gallery
My 06 4cyl when you start it and especially when it cold it goes to 2000 rpm. Dealer says it to get it up to temp asap. I have always been told that cold starts and excessive rpm is very hard on an engine.... any comments...???...
Old 11-11-2010, 12:31 PM   #2
kite will become famous soon enough
kite's Avatar
kite's Tacoma Gallery
2000RPM isn't excessive.
My '05 4cyl does the same thing.
Old 11-12-2010, 02:59 PM   #3
4 cyl start up
I just don't like the way it races when it is first started... When the oil is cold and a fast engine means more metal ware. I have been informed that this sop now as per epa reg's to get the engine up to temp asap. I don't know for sure, but I am not happy...
thanks it is nice knowing I am not alone..
buck
Old 11-12-2010, 03:14 PM   #4
I have a problem for your solution…
Snowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shed
Snowman's Avatar
Snowman's Tacoma Gallery
Its not anything new. My '89 honda prelude had a cold idle at around 2k.
Old 11-12-2010, 03:16 PM   #5
The One The Only
rhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shed
rhion82's Avatar
rhion82's Tacoma Gallery
yeah I've always wondered the same thing. I always wait a minute or two when I first crank it up anyway.
Old 11-12-2010, 03:28 PM   #6
A7XTaco is one of the sharper tools in the shedA7XTaco is one of the sharper tools in the shedA7XTaco is one of the sharper tools in the shedA7XTaco is one of the sharper tools in the shedA7XTaco is one of the sharper tools in the shedA7XTaco is one of the sharper tools in the shedA7XTaco is one of the sharper tools in the shedA7XTaco is one of the sharper tools in the shedA7XTaco is one of the sharper tools in the shedA7XTaco is one of the sharper tools in the shedA7XTaco is one of the sharper tools in the shed
A7XTaco's Avatar
A7XTaco's Tacoma Gallery
Its more important to get the oil circulating as quickly as possible. The higher RPM helps the oil pump and the crank get oil flowing. All engines do it.
Either way, starting a engine is the worse thing you can ever do to one.
Old 11-12-2010, 04:40 PM   #7
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
2,000 RPM isn't racing. It revs up because of the automatic choke.
Old 11-12-2010, 04:50 PM   #8
Almost there
08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed
08pretaco's Avatar
08pretaco's Tacoma Gallery
I have had my RPMS up to 3k + a little bit on a cold start up lol so I dont think 2k is all that excessive
Old 11-12-2010, 10:22 PM   #9
Dafuq
Who Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shed
Who Dat Popcorn's Avatar
Who Dat Popcorn's Tacoma Gallery
It's normal..
It will slowly go down after a minute or so
Old 11-22-2010, 02:22 AM   #10
4cyltacoma will become famous soon enough4cyltacoma will become famous soon enough
4cyltacoma's Avatar
4cyltacoma's Tacoma Gallery
Yeah mine does the same thing. 06 access cab 4x4
Old 11-22-2010, 01:44 PM   #11
tacoma-king has a spectacular aura abouttacoma-king has a spectacular aura about
tacoma-king's Avatar
tacoma-king's Tacoma Gallery
my 97 cold starts at 1500 2k is not all that high
Old 11-24-2010, 07:27 AM   #12
senile member
Tacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shed
Tacoyota's Avatar
Navy: Ex Navy. subs
Tacoyota's Tacoma Gallery
forgive me if i dont quite say these concepts right...
the RPM's are fine , you likely have a lubed engine within 15 seconds or so(normal day) . The oil is thinner,circulates faster, also modern oil is a far cry better than the 70s or 80s stuff. Youll find the RPM's hanging on the shift to 5th too if you have a manual, its normal. Also when warming up an engine / leaving the driveway,its how you load it up that can bad on the engine... meaning the obvious, dont turn it on and show off its acceleration or pull a big trailer immediately.
Old 11-25-2010, 11:05 PM   #13
rs50fox is on a distinguished road
rs50fox's Tacoma Gallery
The air pump is what causes the higher idlling while the engine is cold. newer vehicles do not have a choke unless it has a carb. its nothing to worry about
Old 11-26-2010, 06:40 PM   #14
RedYoter10 is on a distinguished road
RedYoter10's Avatar
RedYoter10's Tacoma Gallery
It can't be too bad for it, considering they use 0W-20 for oil in the new 2.7's!
Old 11-26-2010, 06:47 PM   #15
Banned
Lol. We don't have carbs.
Old 12-07-2010, 08:36 AM   #16
Trever1t is on a distinguished road
Trever1t's Tacoma Gallery
Reviving an old post...
Mine does the same thing ('06 4cyl.) glad to find that it's normal and the "Search" button on this site really works!
Old 12-08-2010, 05:11 PM   #17
San Antonio Detailer :)
Anthony will become famous soon enough
Anthony's Tacoma Gallery
Send a message via AIM to Anthony
yep same here 06 2.7 with 100k
cold starts creeps around 2k then in about 10 seconds goes down to normal
Old 03-08-2013, 05:50 AM   #18
iroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shed
iroh's Avatar
iroh's Tacoma Gallery
Old thread, but previous posts are good reference for my question.
My 07 doesn't rev up when cold much at all and I'm wondering why. Three days ago it was 9 degrees outside; engine temp said 20F and IAT was in the teens before starting the engine. It cold idled at 1300 rpm anyways and that's as high as it ever gets; this seems odd to me considering my 1GR would idle at 1600 cold. Warm idle is typically a stable 650 rpm.
This weekend it's getting new plugs and I'll take a look-see at the throttle body. Any other things to look at?
update edit: nevermind. I pulled four Autolite Double Platinum plugs out of the engine and they were looking pretty bad. With the NGK iridiums in there it went to 1600 rpm first start at 48 degrees outside. I know the other plugs were making its low idle pretty rough so perhaps it was affecting its cold operation too. It did sound like it was spitting a bit but not anymore.
2011.. When starting engine... Xewkija631 2nd Gen. Tacomas 29 03-04-2012 09:01 PM
Trouble starting engine... happens every few months Black 09 2nd Gen. Tacomas 8 02-01-2012 11:36 AM
Horn honks when starting engine xring 2nd Gen. Tacomas 17 01-08-2011 06:39 AM
strange sound when starting engine 07runner 2nd Gen. Tacomas 8 03-12-2009 03:12 PM
cold engine starting difficulties raffy 2nd Gen. Tacomas 14 04-08-2008 06:39 PM
