Taco Towing
Discussion in '4 Cylinder' started by Shakeyfly, Aug 3, 2011.
  1. Aug 3, 2011 at 11:09 AM
    Shakeyfly
    Shakeyfly [OP] Member
    Massachusetts
    2011 Tacoma Access Cab 4cyl 4x4 5 speed
    Hello Everyone, I'm new to the forum. I tried a search function but didn't really see what I was looking for.
    I'm the proud new owner of a 2011 4 cylinder 4x4 access Cab SR5 5 speed. I friggin love the thing. It's just an amazing truck.
    Has anyone here towed a boat with their 4cylinder? I know it says it's rated to 3500 pounds, but I'm just looking for actual real experience with doing it.
    If you did tow a boat what kind of boat is it? I have no delusions of a 20foot center console, but what about 18 foot aluminums? like a lund? Do you find the tacoma pulling say 3000 pounds COMFORTABLY? or is 2000 kinda the area where the truck can really handle pulling okay?
  2. Aug 3, 2011 at 4:31 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Haven't pulled a boat yet, but I pulled a jet ski (~800 lbs.) in my truck loaded with gear, and it pulled like a champ. I feel that it would pull 1.5 to 2k pretty well, beyond that I couldn't tell you.
  3. Aug 4, 2011 at 3:52 AM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    Depends what you mean by comfortably. It will do it safely but you will have to downshift and won't be able to maintain cruising speed going up hills. I've towed 2000lbs and it was fine; I would tow 3000 but wouldn't expect it to go anywhere fast.
  4. Aug 7, 2011 at 8:43 PM
    JoeBama
    JoeBama Well-Known Member
    Joe
    Arab, Alabama
    '10 PreRunner SR5 speedway blue
    Westin nerfs, Smitty bull, Undercover SE tonneau (all black)
    I have basically the same truck : 2010 prerunner sr5 5 speed
    I tow a 16 ft. basstracker with 40hp outboard. Don't know the exact weight, but I feel like its a load back there, especially going up the mountain. Of course the ultragauge shows the mileage going to crap. However made a 350 mile trip to Destin towing a motorcycle (550 lbs) on a small trailer, and got 21.8 mpg.
  5. Aug 7, 2011 at 9:45 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    a general saftey rule of thumb is to keep it under 70% of tow capacity. Sure you can max it out but that is never good for it. For 4 bangers they do pretty well. I had an almost 1000 lb flat trailer on my 2.4 and could hardly tell it was there. Im proud of the taco haha.
  6. Aug 8, 2011 at 1:31 PM
    AlexA
    AlexA Well-Known Member
    Alex
    Newport News, VA
    2012 DCSB Prerunner SR5
    i tow a 2500 lb boat plus gear, a couple miles to the ramp and back on the weekends!
  7. Aug 13, 2011 at 4:45 PM
    SR54x4
    SR54x4 Well-Known Member
    Mark
    Hudson Valley
    2008 4x4 TRD SR5 Tundra
    Magnaflow 12588, TSC lo-pro extra deep toolbox, step bars and bull bar
    bump, im looking to get a boat for next summer and wondering how my 4cyl 4x4 could handle 3,000 or so lbs. i know its not going to win any races, but dont want to destroy it either, clutch is my main concern. being 4x4 i can use 4lo at the launch.
  8. Aug 15, 2011 at 12:14 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    I just moved a couple hundred miles and made about 8 trips towing a loaded 8' trailer and the truck loaded to the max. I'd guess a couple of the loads were 3500-4000 lbs and most were well over 2500 lbs. No problem! Just keep in mind that you're going to run a gear lower than normal, keep the rpm's up and the go-to gear is 3rd on very steep inclines. I had no problems whatsoever keeping highway speed.
    That little 4 is amazing!
  9. Aug 15, 2011 at 5:03 PM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    I tow my sail boat with it, but the entire load isn't more than 300 lbs. sometimes i forget its back there. :p
  10. Aug 17, 2011 at 4:49 AM
    TacomaTommy
    TacomaTommy Member
    JT
    Rocky Mountain Foothills, Alberta
    2006 SR5
    fogs, tonneau, hitch, gps, rims
    I tow my 18' SeaRay ski boat with my 2.7 auto. Weighs around 3000lbs loaded up. Acceleration is snail-like but it pulls at 60 on the freeway and up moderate hills fine, but bogs down on steep grades. Launches & pulls the boat out without spinning and I don't have any kind of diff lock. The 2.7 is adequate, just don't expect to get anywhere in a hurry.
  11. Aug 19, 2011 at 3:39 PM
    LOU G
    LOU G New Member
    Lou
    NY
    2007 4cylinder, manual trasnmission, 68,000k
    I am looking for a pull behing camper to tow behind the 2007, 4 cylinder, manual transmission, 4+4.
    I am wondering how much it can weigh and still be safe and fuctional. Normally, a camper is loaded another one third of it's weight with contents (usually 500/600 lbs). Can I pull a 2,000 trailer (plus 500/600 lbs) with this vehicle. What mods (transmission cooler) would be necessary, if any.
    I have only owned for a month and I am very pleased with the vehicle. Thank you in advance for any help you can provide.
  12. Aug 21, 2011 at 9:36 AM
    ohdrj1all
    ohdrj1all Well-Known Member
    AZ
    2003 XtraCab 4x4 SR5 2.7L 5spd
    Anyone on here towing a side-by-side (like a Rhino 660) and trailer with a 2.7L? We are considering getting one and while I know the wife's Jeep Commander can tow it no problem... would like to tow it with my Taco too if needed.
    Thx.
  13. Aug 24, 2011 at 2:38 PM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Icon Stage 2 Coilovers, Camburg UCAs, 33x12.50x15 Dick Cepek Trail Country EXP on American Racing AR201 15x10 wheels, differential drop, carrier bearing drop, BPV bracket, Leer canopy with Rhino Racks
    My grandparents towed an old 15' or so wooden boat with their volkswagen bug and it did fine. I'm sure your tacoma could tow more than you think.
  14. Aug 24, 2011 at 2:55 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Some crazy responses here IMO, I wouldn't tow anything over 1500 lbs max with your truck. Anything more is just pushing it.
  15. Aug 25, 2011 at 11:05 AM
    sc300fivespd
    sc300fivespd Member
    Pirooz
    94583
    white taco
    toyota tool box
    i wanted to pull a tow dolly with my sc300 attached to that.. the tow dolly isnt more than like 250lb im guessing and my SC is about 3800.. soo like 4500lb max and thats just pulling not alot of weight in the ball.. should i be okay?
  16. Aug 25, 2011 at 3:27 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Sloooow on the start, and a little struggle with steep hill starts but other than that its like a champ.
  17. Aug 25, 2011 at 5:12 PM
    AlexA
    Alex
    Newport News, VA
    haha nicely said sir!
  18. Aug 26, 2011 at 11:12 AM
    Shakeyfly
    Massachusetts
    Great stuff guys! Thanks for the responses?
  19. Sep 5, 2011 at 5:11 PM
    bmadison99
    bmadison99 Member
    Brandon
    Maine
    2009 Tacoma SR5
    What do you guys think about pulling a 2600 pound pop up camper from maine to georgia? I have a 2009 2.7 auto, never towed with it yet, have to put the tow package on it yet. Should I get a tranny cooler for this long of a drive? I have no doubt it would be ok towing this around the local area, just wondering about the long distance commute.
  20. Sep 6, 2011 at 2:53 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    On the same token, the 5 lugs sit lower and suffer less from wind resistance, along with the fact that they weigh a few hundred pounds less to begin with.
