LCE Header installed!
Discussion in '4 Cylinder' started by Midway, Oct 8, 2011.
  1. Oct 8, 2011 at 9:38 AM
    Midway
    Midway [OP] Active Member
    Brandon
    Washington State
    11 Regular Cab 4x4
    Leer 100R Canopy, BF-goodrich MT-KM2's 265/75/16, Black 16" MB 72's, Bilstein 5100's set at 2.5" front. Bilstein 5100's in rear. 1.25" Tuff Country blocks, BedRug, LCE Header, , Magnaflow muffler, K&N 63 series intake, TC UCA's and Toytech Diff drop. Vehicle security by GLOCK.
    I'm extremely happy with this header. Amazing quality. I've noticed a real increase in power in the higher RPM range.
  2. Oct 8, 2011 at 9:41 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    You sir, have an extremely well-hooked-up 2TR. +1 for you.
  3. Oct 8, 2011 at 9:42 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    how is the change in sound?
  4. Oct 8, 2011 at 9:46 AM
    Midway
    Brandon
    Washington State
    11 Regular Cab 4x4
    That you sir! As far as the difference in sound, I think it compliments my Magnaflow exhaust. The sound is much deeper than before. Very happy with it.
  5. Oct 8, 2011 at 11:24 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    hmm interesting that you say high rpm
  6. Oct 9, 2011 at 8:09 AM
    Midway
    Brandon
    Washington State
    11 Regular Cab 4x4
    I did get a slight increase in low end power, but from about 1800-3000 is where I noticed the difference. My goal was to make up for some the lost performance due to the heavier KM2 tires. I really wish I would have gotten the manual transmission, over the AT (Wife can't drive MT & refuses to learn). But hey, the bucket seats are nice looking. As far as why I picked LCE over DT, just personal preference. I liked the fact that LCE's research & testing is concetrated on Toyota. I'll be posting some videos soon.
  7. Oct 22, 2011 at 1:10 AM
    joshdoodles
    joshdoodles Member
    josh
    jonesboro, ar
    2011 prerunner sr5 2.7 access cab
    Doug Thorley header, Afe stage 2 air intake with prodry s filter, Access sport tonneau cover, Steelcraft side steps
    I also had to decide between the two and I went with the Doug Thorleys and I really like them as well, I noticed a little more torque in lower rpms. 1700-2600 rpms..which is right where it needs to be for me..I think you'll win either way you go, Ive heard good things about both...I had Doug Thorleys on my Tundra and I loved them, so I knew I wouldnt be dissapointed.......and they were a little cheaper
  8. Oct 27, 2011 at 2:02 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
  9. Oct 27, 2011 at 8:52 PM
    turbothompson13
    turbothompson13 Well-Known Member
    Jay
    Parkersburg, WV
    08 2.7L
    4.5 inch front suspension lift, 3 inch rear end block lifts, 4 inches total lift, k&n cold air intake, racing shocks, front bilstien rear fox shocks, n fab pre runner light bar/bumper with fog lights, 33 inch nitto dune grapplers and ballistic jester 18 inch wheels.
    this is a little off the topic but where did you find those upper control arms? i need some bad and with my lift i am in bad need for some to compensate for that. it looks like you have them.
  10. Oct 27, 2011 at 9:30 PM
    Midway
    Brandon
    Washington State
    11 Regular Cab 4x4
    I bought the Total Chaos UCA's from "Wheeler's Off Road"
    They're worth every penny. When I lifted the front 2.5", the front tires would "Float". As soon as I got the new UCA's installed and got a decent alignment done, the truck handled better than stock.
  11. Oct 28, 2011 at 7:42 AM
    turbothompson13
    Jay
    Parkersburg, WV
    08 2.7L
    and all that you have on it is the link you sent me right? my truck is really stiff in the front because of the bind on the uca's. did it help with how stiff it was too or just the handling, which i need back too.
  12. Oct 28, 2011 at 12:26 PM
    Midway
    Brandon
    Washington State
    11 Regular Cab 4x4
    You have a 5" front lift. What kind of lift? Do you have any pictures of the front end? I would be very interested to see your CV angles. If you're running stock UCA's, I could see why the ride is so bad.
    For my setup, (Adjustable 5100's up front with stock coils) I had the 5100's set at 2.5", so I knew it would be a gamble when it came to ride/handling. After the installation I had an alignment done (the first time) and couldn't not get the caster to spec. The truck was safe "enough" to drive, but I didn't feel it was worth the risk of burning the tread off my new KM2 tires. I ended up buying the new UCA's, had them installed, and got a 2nd alignment done. I noticed an immediate difference. No more "floating" type feel, Great alignment numbers, and a little bit more down-travel.
    If you could provide more information about your lift, it would help.
  13. Oct 28, 2011 at 12:33 PM
    turbothompson13
    Jay
    Parkersburg, WV
    08 2.7L
    well believe it or not i only had the 5100 levelling kit, was supposed to be for 2.5 inches, and i had it put on by the only off road shop near me. when i came to pick my truck up they had it looking like it was popping a wheelie, and my levelling kit ended up being almost right at a 5 inch lift in the front. they had the parts around to put 3 inches on the rear and it was cheaper than re adjusting the front shocks because of the coils. so the cab of my truck lifted by 4 inches in the end. how it worked that way i have no clue, i have wondered from the beginning if i have a wrong part or something but dont have the money to keep trying new things. i can try to upload some pictures of my uca's. its kinda crazy tho and its been on for over a year and so far so good. so now i plan on fixing some of the issues that the lift caused, so i am putting a differential drop on and going to get new uca's.
  14. Oct 28, 2011 at 12:36 PM
    turbothompson13
    Jay
    Parkersburg, WV
    08 2.7L
    [​IMG]here is one of the only pictures that i have of my truck right now.
  15. Oct 28, 2011 at 12:49 PM
    06aztaco
    06aztaco Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
    He says 1800 to 3000 rpm, but that IS low end. Not high end. Problem solved.
  16. Oct 28, 2011 at 12:50 PM
    Midway
    Brandon
    Washington State
    11 Regular Cab 4x4
    Wow. Yeah, when you have the time, take a few pictures of your lift. I just want to see if they "stacked" your lift. Adding new UCA's and dropping the differential will really help. :popcorn:
  17. Oct 28, 2011 at 12:54 PM
    turbothompson13
    Jay
    Parkersburg, WV
    08 2.7L
    yeah i will try to get some pictures either tonight or tomorrow. what do you mean by "stacked" tho?
  18. Oct 28, 2011 at 6:19 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    quick question for ya there ba, is it easy to make the truck quiet? like reving no higher then 2000-2500 usually, will kill alot of the sound from both exhaust and header?
  19. Oct 29, 2011 at 12:13 AM
    turbothompson13
    Jay
    Parkersburg, WV
    08 2.7L
    i know im not the guy your asking that question to, but i have muffler on mine, basically made into a cat back, and its loud if im above 3 grand, but if im around 2 to 3 then its not too loud at all.
  20. Oct 29, 2011 at 7:11 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    thanks for the info. do you have a header too?
