1999 Toyota Tacoma timing chain?
Old 10-31-2011, 06:40 PM   #1
Whyareyoureadingthis?
VirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shed
VirginiaBound's Avatar
Name: Sam I am, green eggs and ham
VirginiaBound's Tacoma Gallery
Just to clear things up, my 2.7 takes a timing Chain correct? Or does it take a timing belt?
Edit: I've read in three posts that it does infact take a chain. I'm back to step one I suppose.
I had to get it towed to a mechanic today after it started sputtering and idling extremely rough. Also smelled a very strong sulfur smell from the exhaust like un-burnt fuel.
I've checked sensors and everything is connected, hopefully the mechanic can figure it out.
Old 10-31-2011, 06:49 PM   #2
Turp has much to be proud ofTurp has much to be proud ofTurp has much to be proud ofTurp has much to be proud ofTurp has much to be proud ofTurp has much to be proud ofTurp has much to be proud ofTurp has much to be proud of
Firefighter: Operations: Fire, Technical Rescue, EMS
Turp's Tacoma Gallery
Timing chain. usually lasts quite a few miles; 200K+ from reading posts. A search in the 4cyl section will provide more details.
Old 10-31-2011, 06:52 PM   #3
Ok, thank you for confirming that Turp.
Looks like a very complicated job if it does break, I'm keeping my fingers crossed mine didn't go at 260,000 miles.
Old 11-04-2011, 07:30 AM   #4
wolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud of
wolfgang123's Avatar
wolfgang123's Tacoma Gallery
it didn't trust me you would know if it broke...might have loosened and splipped a tooth though
Timing belt or Timing chain on all Toyotas. From Toyota.com genxer36 Technical Chat 40 12-05-2013 11:10 AM
Replacing timing belt on 1999 Tacoma bengreen 1st Gen. Tacomas 0 12-29-2011 09:10 AM
Do all 2005 4x4 v6 tacoma have a timing chain? ttonon17 2nd Gen. Tacomas 5 04-01-2011 07:26 AM
2000 tacoma 2.7l timing belt or chain? replacement? HELP! Panda Cub 4 Cylinder 4 12-07-2010 02:14 PM
1995 Totota Tacoma Timing Chain dologiles 1st Gen. Tacomas 5 12-29-2009 09:20 AM
