PrezidentRedz' 2000 Tacoma 4x4
99 Tacoma Electrical Problem?
Old 11-27-2008, 08:09 PM   #1
mcvoss is on a distinguished road
mcvoss's Tacoma Gallery
Hello,
My son has a 99 Tacoma 2.4
Yesterday the truck would not start, he had some blown fuses. EFI, dome light. We replaced all of them.
Truck still wont start not a sound from starter, it is just dead. Items that should work with accessory on do not, such as radio, turn signals.
Everything that is supposed to work with ignition off DOES work, headlights, dome light, hazards etc.
Any ideas where to look, relay, master fuse? It is a brand new battery..
Thank You
Old 11-27-2008, 08:55 PM   #2
WESTern Alliance: NORCAL COAST
BeefTaco is a splendid one to beholdBeefTaco is a splendid one to beholdBeefTaco is a splendid one to beholdBeefTaco is a splendid one to beholdBeefTaco is a splendid one to beholdBeefTaco is a splendid one to beholdBeefTaco is a splendid one to beholdBeefTaco is a splendid one to behold
BeefTaco's Avatar
BeefTaco's Tacoma Gallery
Was the truck jumped backwards you know positive on negative and negative on positive sounds like a lot of fuse's ? Use the below link scroll to the bottom to the wiring diagrams look at relay locations page 21 fuse box R/B 2 this is located under the hood in there is where medium and high current fuses are located check to see if one is blown.
http://www.ncttora.com/fsm/2000/index.html
__________________
Old 11-28-2008, 12:16 AM   #3
BeefTaco,
I believe it was jumped incorrectly.
What is the best way to test a relay and any suggestions which one I should start with.
Thank You for your help!
Old 11-28-2008, 07:48 AM   #4
BeefTaco's Avatar
The fuses to check would be AM1 and AM2 also the 120 amp ALT fuse. These fuses are in the fuse block R/B No.2 in the engine compartment they are the larger pink fuses in the back of the fuse block they have a plastic top on them use a flash light to see if they are blown. They are difficult to check with a test light but more than likely they are your problem for the no start and no power into the truck.
__________________
Old 11-28-2008, 08:30 AM   #5
Western Aliance: Fix it Division
chris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond repute
chris4x4's Avatar
chris4x4's Tacoma Gallery
Also, look around for any wires in which the coating may show signs of melting, or excessive heat. I had a friend jump my Chevy and he reversed the jumper leads. one wire in the back going to the ignition burned up. No fuses blew. Truck wouldnt start, but everything worked until I replaced that wire, and then promptly smacked my friend in the head.
__________________
The simplest solutions are often the most clever..............they are also usually wrong.
Old 11-28-2008, 07:39 PM   #6
THANK YOU!!
Yes it was the Alt fuse that was blown. You are right those are hard to see.
Thanks again for the quick and accurate responses
Have a great Holiday Season.
Michael
Display Modes
Electrical Problem surfsupl 2nd Gen. Tacomas 1 11-14-2008 07:06 PM
Need help! electrical problem Ramathorn Technical Chat 1 03-04-2008 05:08 AM
electrical problem A1CGuches 1st Gen. Tacomas 5 12-18-2007 05:04 PM
Problem with my tacoma 2000. west coast Performance and Tuning 3 05-25-2007 07:41 PM
electrical lexusoftrucks 2nd Gen. Tacomas 10 01-10-2007 12:45 PM
Copyright © 2009 Tacoma Forum
