02 SR5 Engine Knock
Discussion in '4 Cylinder' started by ButchL1947, Feb 13, 2012.
  1. Feb 13, 2012 at 9:00 AM
    ButchL1947
    ButchL1947 [OP] New Member
    Butch
    02 Tacoma SR5
    Just turned 116K and started hearing engine knock on cool mornings at low RPM's sound quickly ends upond short warm up - repair guy says "its a rod" and need to rebuild or replace engine - thoughts?
  2. Feb 14, 2012 at 6:21 PM
    dip
    dip Member
    NE Ohio
    01 Tacoma
    I have an 01 and it does it when cold sounds awful. Some say piston slap others say carbon buildup. I have read IF it was under warranty they replace the short block. Mine has been doing it a while and I am getting rid of it this spring. Something is going to break at some point. I have 181,000 on my truck.
  3. Feb 25, 2012 at 6:59 AM
    fwrhodes
    fwrhodes New Member
    franklin
    Denver, CO
    2000 Tacoma SR5
    I have a 2.7L 2000 tacoma and I noticed it knocking a couple of years ago on cold Colorado mornings. In the winter I started to use premium gas and I upgraded to Mobile 1 synthetic oil. That seems to really combat our issue!
  4. Mar 7, 2012 at 6:20 AM
    2001taco
    2001taco New Member
    North Carolina
    2001 reg cab SR 5speed 2.7 4x4
    I have a 2001 that has had the knock you guys are talking about since about 85k it now has 203k with absolutely no issues. I say just give it time to warm up then.
  5. Mar 7, 2012 at 6:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    The knock is pre-igniton (aka detonation). It is the fuel burning before the piston reaches TDC causing the energy to be applied to the piston while it is still on the compression stroke.
    There are several causes to this:
    • timing
    • carbon build up
    • bad or low octane gas
    A quick fix is running the higher octane gas but that is only a band aid and does address the root cause. I'd suggest running seafoam in the tank a few times. and go from there.
  6. Mar 7, 2012 at 11:07 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Detonation during cold start? Seriously? I hear the same knocking on cold start if it's below 50*F... I have read around and the concensus is that the knock is a bit of piston slap due to looser tolerances in an engine that's worn-in and started cold. The sound can be annoying but in my truck it stops after 1-2 minutes and the engine always runs superb. I am not worried.
  7. Mar 7, 2012 at 6:48 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    I have the same noise and ticking. No worries
  8. Mar 8, 2012 at 3:56 AM
    2001taco
    2001taco New Member
    North Carolina
    I have ran enough seafoam and high octane for everyone in here. I have ran the seafoam through the fuel and also induced through the intake. If anything it made my knock worse.
  9. Mar 9, 2012 at 7:00 AM
    LoneWanderer
    LoneWanderer Well-Known Member
    Randy
    Ohio
    03 4x4 Access Cab 2.7l 5spd
    Bilstein 5100s, Rancho Quick Lift struts, Wheelers 3 leaf aal, Procomp 8069s, General Grabber AT2 31x10.5, AFE Pro Dry S air filter, Dynomax Super Turbo muffler
    Have the exact same thing. Mine started this Winter. 115k miles. Seems to do it when its under ~45F degrees. Now I always let it idle for about 20 or 30 seconds before I take off when its cold and then it runs like a champ. I'm not worried about it unless someone here has a reason to be.
