155,000 blown head gasket
Discussion in '4 Cylinder' started by tacocasey, Apr 12, 2012.
  1. Apr 12, 2012 at 3:23 PM
    tacocasey
    tacocasey [OP] New Member
    casey
    bend oregon
    stock
    none
    Hey, I'm new here. My name is Casey, blablabla. I have a 1995 2.7L tacoma that the head gasket recently went out on. Looks like it is going to be about $800ish to fix that. $3200 for a rebuilt long block and $2000 for an aftermarket online. What would you guys do? Is there any high performance 2.7's worth looking at? Supra swap? I would love your opinions.
    p.s. yes, I used the search...:D
  2. Apr 12, 2012 at 3:27 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I'd pull the head and get it checked for warpage.
    If warped, get it machined and put it back together with a high quality head gasket.
  3. Apr 12, 2012 at 3:44 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I would get them machines and and new gaskets and probably do all the maintenance on it that hasn't been done in a while just search online on how to and you can do this your self
  4. Apr 12, 2012 at 4:14 PM
    tacocasey
    casey
    bend oregon
    stock
    none
    I'm trying to decide if at that many miles I should just get a long block and swap it out. Seems a little on the early side for the head gasket to go.
  5. Apr 12, 2012 at 4:53 PM
    Tacon
    Tacon Member
    I'd run an engine compression test to get an idea of engine health.
    I'd check timing chain slop which can affect timing and cause other damage if very loose.
    Inspect oil for metal or coolant contamination.
    Also what Steve said.
