2.7l is weak, should I regear???
Old 04-25-2012, 05:56 AM   #1
00PreRunner is on a distinguished road
00PreRunner's Avatar
00PreRunner's Tacoma Gallery
I have a 2000 Prerunner with the 2.7l and auto tranny. The truck is very weak off idle and gets bad gas mileage around town. A friend has a set of 4.30's I can use to swap out my 3.91's. My question is how high will my rpms be going down the interstate and how off will my speedo be? Thanks
Old 04-25-2012, 06:30 AM   #2
The Polar Bear
Devux is on a distinguished road
Devux's Avatar
Devux's Tacoma Gallery
I can't quantify anything for you but in general going from a 3.91 to a 4.30 your performance (acceleration distance) will increase, your fuel mileage is going to drop, and your highway RPMs are going to be higher.
If you're looking for a performance increase it might be worth looking into a good exhaust system, intake, hot ignition and high performance plugs and plug wires. My dad did a mild tune to his '98 Rodeo (4 Cylinder), it gave it a bit more oomph, he's happy with it. Better than messing with the rear gear in my opinion.
Old 04-25-2012, 06:32 AM   #3
Thanks for the advice. I'd much rather look into exhaust and intakes then gears.
Old 04-25-2012, 05:44 PM   #4
afd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shed
afd23a's Avatar
afd23a's Tacoma Gallery
try this website http://www.grimmjeeper.com/gears.html
You'll have to look up the gears in your transmission, but it's seems pretty accurate
Old 04-25-2012, 06:01 PM   #5
worthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shed
worthywads's Avatar
worthywads's Tacoma Gallery
The math is really simple.
Current rpm times 4.30/3.91 or 1.1
If you are 2500 at 60 now you will be 2500 * 1.1 = 2750.
Old 04-26-2012, 05:58 AM   #6
Thanks for the help. I'm adding cruise control here in a few days. I'll see if that makes a difference.
Old 04-26-2012, 07:08 PM   #7
tan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shed
tan4x4's Avatar
tan4x4's Tacoma Gallery
I have a 2.7 with automatic, and it has 4.56 gears from the factory.
Are you sure you have 3.91's? What is your axle code on the door jamb?
Old 04-26-2012, 07:14 PM   #8
Almost there
08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed
08pretaco's Avatar
08pretaco's Tacoma Gallery
have you done a head to toe tune-up on the motor/vehicle?
Old 04-30-2012, 05:49 AM   #9
The code on the door is B06A. From what I can tell, that means it has an 8" diff, 3.91's, and an open rear end. And no I haven't tuned it.
Old 05-01-2012, 10:40 AM   #10
Dangerous
ronman737 is one of the sharper tools in the shedronman737 is one of the sharper tools in the shedronman737 is one of the sharper tools in the shedronman737 is one of the sharper tools in the shedronman737 is one of the sharper tools in the shedronman737 is one of the sharper tools in the shedronman737 is one of the sharper tools in the shedronman737 is one of the sharper tools in the shedronman737 is one of the sharper tools in the shedronman737 is one of the sharper tools in the shedronman737 is one of the sharper tools in the shed
ronman737's Avatar
ronman737's Tacoma Gallery
New spark plugs(platinum or iridium), Afe pro dry or K&N air filter. I bet you will feel a difference. Also, do the seafoam mod. 1/3 bottle in the gas tank,1/3 in the oil (pre oil change, ride on it for about 1000 miles to let it do some work) 1/3 bottle in the intake manifold. Ill try to find the thread on it for you.
Old 05-01-2012, 10:43 AM   #11
"Pick up some speed.. You'll make it."
BuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shed
BuzzardsGottaEat's Avatar
Marines: 3rd Battalion, 1st Marines
BuzzardsGottaEat's Tacoma Gallery
I second the tune up. And if that's not sufficient the intake/exhaust options. . .
Old 05-01-2012, 11:10 AM   #12
Trifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shed
Trifenix's Avatar
Trifenix's Tacoma Gallery
Usually only regear if you are running larger tires. Do a tune up.seafoam. aftermarket air filter. Your truck is just slow. Buy a v6 or v8.
Old 05-01-2012, 12:11 PM   #13
Dangerous
ronman737's Avatar
http://www.tacomaworld.com/forum/1st...0-seafoam.html
post 36!
Old 05-02-2012, 05:45 AM   #14
Thanks for the seafoam link
2.7L auto weak with error code p0402 "EGR EXCESSIVE FLOW" outlaw8950 1st Gen. Tacomas 20 10-07-2014 07:51 AM
Regear Tacokevin North East 4 12-01-2011 10:22 AM
Differences: 1997 2.7L vs 2001 2.7L cab4you26 1st Gen. Tacomas 5 05-19-2011 09:07 AM
2TR w/33's and regear/no regear info wanted 08pretaco 4 Cylinder 147 01-29-2011 02:01 PM
03 2.7l vs 09 2.7l glockaxis 4 Cylinder 11 08-17-2009 06:17 AM
