Do these spark plugs look normal for 40K?
Old 05-20-2012, 02:06 AM   #1
BBYE V8 [OP] BBYE V8 is offline
Please keep TW beautiful: search & stay on topic
BBYE V8 is one of the sharper tools in the shedBBYE V8 is one of the sharper tools in the shedBBYE V8 is one of the sharper tools in the shedBBYE V8 is one of the sharper tools in the shedBBYE V8 is one of the sharper tools in the shedBBYE V8 is one of the sharper tools in the shedBBYE V8 is one of the sharper tools in the shedBBYE V8 is one of the sharper tools in the shedBBYE V8 is one of the sharper tools in the shedBBYE V8 is one of the sharper tools in the shedBBYE V8 is one of the sharper tools in the shed
BBYE V8's Avatar
BBYE V8's Tacoma Gallery
I pulled the spark plugs today to put some anti-sieze compound on the threads. It's just a simple safe thing to do if I'm going to run these plugs to the recommended 100K miles. Everything seems fine with the truck as well as the spark plugs, except for the way the porcelain looks kinda burnt:
Is this a common, harmless event with the 2TR or the Denso plugs? Or is it a problem? And after only 40K miles? Given how cheap they are, I'm leaning towards replacing them just for peace of mind. But I'd like to know what, if anything, is wrong here.
Old 05-20-2012, 02:13 AM   #2
Nothin
krimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shed
Gender: Trans
krimson's Tacoma Gallery
It's common, the burnt part of the porcelain is no longer sealed to the metal part. It's A good idea to change spark plugs at 30k miles.
Old 05-20-2012, 07:43 AM   #3
george3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shed
george3's Tacoma Gallery
I think you have a good idea "to put some anti-sieze compound on the threads" 2.7's with iridium plugs are supposed to be good for 100,000. The guys that are saying change them at 30,000 have 4.0 and they are correct for that motor. 100,000 is scary just because they could be welded in by then so the anti-sieze compound at 40,000 should solve that problem.
Old 05-21-2012, 08:29 AM   #4
2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed
2004TacomaSR5's Avatar
2004TacomaSR5's Tacoma Gallery
That is the cleanest looking spark plug tip I have ever seen! But that is coming from a guy that has only changed plugs on carbureted motors where a lot more carbon and gunk build up on the plugs, I have never changed a fuel injected plug before. I think they recommend you change the plugs every 100k on these trucks, not sure though.
Old 05-21-2012, 08:33 AM   #5
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
x2, 30k mile interval is for the V6 engine.
Those look a lot better than mine did at 40k miles (I have a V6 and should have changed them at 30k miles ).
Old 05-21-2012, 08:56 PM   #6
BBYE V8's Avatar
Originally Posted by Idaholandho View Post
This discoloration is generally called "Corona stain"
Thanks for that...I googled that phrase and found a bit more. Glad to know nothing is wrong. I've had old plugs with a small tan ring around them, but nothing like this big dark brown/burnt oil stain.
Old 05-21-2012, 09:00 PM   #7
Rich91710's Avatar
Rich91710's Tacoma Gallery
Ya, that's corona.
The clue is the "looping" you can see in the ghosting of the stain.
That is the corona being affected by the magnetism in the steel shell.
Had that not been present, and had that been a Champion plug, I'd have said that the plug has broken it's seal and should be replaced.
But I've never heard of Denso having problems with seals.
Old 05-22-2012, 12:14 PM   #8
DGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shed
DGXR's Tacoma Gallery
Don't they put anti-seize on the plugs at the factory? My 2TR has 70k miles and runs perfect, so I hadn't planned on taking the plugs out before the 100k recommended replacement... unless there might be an issue getting them out of the head...?
Old 05-22-2012, 07:55 PM   #9
afd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shed
afd23a's Avatar
afd23a's Tacoma Gallery
I replaced mine at 100k with no problems whatsoever and they looked almost exactly like that. There was no difference in how the truck ran after I changed them.
Old 05-23-2012, 01:05 AM   #10
That's good info. How was the gap
Old 05-23-2012, 08:15 PM   #11
afd23a's Avatar
Sorry don't remember. It's been 25k ago.
Old 05-24-2012, 05:09 PM   #13
afd23a's Avatar
OK. Did you regap them or just put them back in ?
I replaced them with new OEM Denso Iridiums. Checked the gap on the new ones and they were pretty close to spec. Can't remember what the spec is though.
Old 05-24-2012, 05:13 PM   #14
Since they came out without a problem do you think you will wait til 100,000 next time
Old 05-24-2012, 07:25 PM   #15
afd23a's Avatar
Yep, that's the plan.
Old 05-25-2012, 03:40 AM   #16
Thanks. I was going to take mine out to make sure they didn't get "welded" in but with the benefit of your experience I don't think I'll bother til 100,000.
Old 05-25-2012, 11:23 AM   #17
Rich91710's Avatar
Wife's '04 Rav4 was fine at 100k.
Parts guy at the dealership actually tried to talk me into the cheaper plugs. Told him I don't mind the extra cost for the infrequent changes.
Old 05-25-2012, 11:52 AM   #18
Agreed. Your time - my time is worth more then the extra charge.
Old 05-29-2012, 08:04 PM   #19
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
Platinum tip or iridium tip plugs are fully able to last for 100k miles. While there is no need to replace them at 30k at all, it is not a bad idea to apply anti-size on the threads. Just make ABSOLUTELY sure that you don't get any on the tip.
Old 12-26-2012, 08:29 PM   #20
canucktacoma is on a distinguished road
canucktacoma's Tacoma Gallery
i pulled my iridium@130km,,came out easy but i chkd gap,rifght on money,,hard to believe dealer about the 192km srvc,put anti seize to make life easier later..were very clean.
Spark Plugs? RollTideJon 2nd Gen. Tacomas 17 02-03-2012 12:08 AM
Spark plugs Hektor 1st Gen. Tacomas 7 12-27-2011 05:57 PM
Best spark plugs for 4.0 Bsfilter 2nd Gen. Tacomas 11 09-15-2011 03:23 PM
Spark plugs? Bamahoyt 2nd Gen. Tacomas 22 01-28-2011 03:14 PM
What spark plugs to use? slimcubby 2nd Gen. Tacomas 2 01-22-2009 03:01 PM
