2012 Texas Built Single Cab Cruise Control
Old 05-26-2012, 04:10 PM   #1
Ebby1600 [OP] Ebby1600 is offline
Ebby1600 is on a distinguished road
Ebby1600's Tacoma Gallery
Project complete.
1. Wanted to add cruise control.
2. Read the forum threads here and Toyota Nation
3. Bought OEM stalk, connecting wire, and side cover.
4. Installed all.
5. No Joy.
6. My truck is a "non-prewired Tacoma" for cruise control.
7. More research and found a company called Rostra.
8. They sell a complete kit for "non-prewired Tacomas".
9. I don't need a whole kit.
10. Ah ha...Rostra sells a prefab wiring kit for non-prewired Tacomas.
11. Had to go through a distributor to order: Brandon Distributing
12. Costs about $12.00 and has the wires for Cruise panel light, cruise switch, ground wire and another wire if you have manual tranny. Some cusioning material and some wire ties.
13. Downside...shipping was like $15.00
14. Wires have the correct clockspring terminals done very nicely.
15. Instructions are on Rostra website as a PDF file.
16. Downside...much of the trim covers on the instrument panel must be removed. Do a search on installing OEM fog lights for some nice pictures on how to remove most panels. They actually came off pretty easy. Just don't force anything or break a clasp.
17. Followed the Rostra/TN/TW instructional information.
18. Ops check good.
19. Mission accomplished.
20. Cruise is now my latest mod.
A big thanks to Tacoma World, Tacoma Nation, the people at Rostra and Brandon.
Old 05-27-2012, 04:14 AM   #2
wolftree is a glorious beacon of lightwolftree is a glorious beacon of lightwolftree is a glorious beacon of lightwolftree is a glorious beacon of lightwolftree is a glorious beacon of lightwolftree is a glorious beacon of light
wolftree's Tacoma Gallery
I am curious. What did have to pay for the side cover?
Old 05-27-2012, 04:02 PM   #3
2012 Texas Built Tacoma Cruise control steering wheel side cover
$4 0R $5 Dollars and it fit perfect. P/N 45186-0C020-B0. They changed the steering wheel in 2012.
Old 06-09-2012, 08:42 AM   #4
tlh178 is on a distinguished road
tlh178's Tacoma Gallery
question for ebby, can you tell me exactly were you placed the 4 wires from rostra? i'm confused about were to mount them? or if anyone else can answer?
Old 06-10-2012, 05:40 AM   #5
Ming42083 is on a distinguished road
Ming42083's Avatar
Ming42083's Tacoma Gallery
your welcome
Old 06-10-2012, 04:58 PM   #6
Thumbs up 4 wires for cruise control
One is a ground.
One is power to the cruise switch
One is power to the cruise indicator lamp
One is to be used if you have a standard transmission
What I did was download complete instructions from the Rostra website. It's a pdf document .
To wire the cruise lamp on the panel requires the removal of several panels on the dash. A lot of work but worth it for a complete install. My motivation for buying the Rostra kit was for the correct clockspring connectors. I wasn't about to try sticking wires in theconnectors and using tape to secure.
There are lots of good photos from other projects to help with the removal of panels. Good luck with your project.
Old 06-14-2012, 06:37 AM   #7
(Not the real George Strait)
GEORGE STRAIT is one of the sharper tools in the shedGEORGE STRAIT is one of the sharper tools in the shedGEORGE STRAIT is one of the sharper tools in the shedGEORGE STRAIT is one of the sharper tools in the shedGEORGE STRAIT is one of the sharper tools in the shedGEORGE STRAIT is one of the sharper tools in the shedGEORGE STRAIT is one of the sharper tools in the shedGEORGE STRAIT is one of the sharper tools in the shedGEORGE STRAIT is one of the sharper tools in the shedGEORGE STRAIT is one of the sharper tools in the shedGEORGE STRAIT is one of the sharper tools in the shed
GEORGE STRAIT's Avatar
GEORGE STRAIT's Tacoma Gallery
Ebby, how do you know if your truck is prewired or not? Were previous models prewired?
Old 06-15-2012, 05:21 AM   #8
I bought the cruise stalk, installed it and it didnt work. When the covers off your steering wheel look for the S8 plug towards the bottom of the column. If you only see a green wire then you are not wired for cruise.
Old 07-21-2012, 08:13 AM   #9
poohhill is on a distinguished road
poohhill's Tacoma Gallery
Smile
Is this part required or can you mod your side panel by making your own hole? I thinking the CC kit come with a template to do this but not sure.
Old 07-21-2012, 02:10 PM   #10
guess it depends on which kit you buy. if you buy the rostra kit, it comes with the template. then you would need the right drill bit for the template. i went oem cc and brought the steering cover. sure is nice having cruise and real wipers!
Old 07-25-2012, 01:22 PM   #11
cameron172 will become famous soon enough
cameron172's Avatar
Navy: Student Naval Aviator
cameron172's Tacoma Gallery
I attempted to install today and got mostly done. I installed the hardware and ran the wires I got from the Rostra kit. My truck is not prewired for cruise control and I have one thing left:
I got really confused what to do with the wires from the clutch disengage switch and what wires to use the t-taps on. I have everything connected on the passenger side and the steering column, but I just have no idea how to connect everything into the junction box. Ideas or experience?
Old 07-25-2012, 06:43 PM   #12
you will have two wires coming out of the clutch switch, one wire goes to the lite green wire in your junction box, which is left of the steering wheel. just tap into that one. the other wire goes to the ecm, if you have 2trfe motor. you would use pin 21 on ecm. if you have 1grfe motor, you wire goes into ecm pin 27. hth
Old 07-26-2012, 08:20 AM   #13
cameron172's Avatar
Okay, thanks. I have one purple wire tapped into the lite green wire in the junction box.
The other purple wire gets mated to the blue wire, right? Should I clip the existing connector on the blue wire so I can connect it with the purple wire?
EDIT: Clipping the blue wire to connect it with the other purple wire worked. I have no cruise light on the dash, so I can't tell if it's on or not, but the cruise control works just fine!
Old 07-26-2012, 07:11 PM   #14
Cool got my CC
Got my CC kit today. Stopped by Toyota and they want $130 to installed. I have a Texas made Tacoma made in May 2012 Single cab with 2.7. So I don't think its prewired cause Ebby says his was not. Think 130 is fair. They said it would take 2 hours. I don't want to tackle the job or should I get another mechanic price. I would like to stick with Toyota since work would be backed up.
Old 07-27-2012, 04:41 AM   #15
go 4 it. if there backing there work. i'm sure sure you could get it done alittle cheaper. i recently did mine, its not that hard.
Old 07-27-2012, 07:08 AM   #16
Talking
Thanks for your replies. Think I will do that for I will probably set off the air bag and break something LOL
Old 07-28-2012, 07:50 AM   #17
cameron172's Avatar
It's not that hard to do it yourself. Rostra has pretty easy instructions here. Save yourself $130. I took my time and double checked everything and it took me around four hours.
But if you're not comfortable with taking things apart or basic wiring, it may be best for you to have someone do it.
Old 08-21-2012, 01:16 PM   #18
cameron172's Avatar
So the cruise control mod worked for about three weeks before I discovered it doesn't work anymore. Tore into the area around the junction box again and found all connections and splices good. Grounding it good.
Is there a fuse I can check somewhere for the CC? Anyone else's randomly stop working?
EDIT: I discovered a loose connection, so I reconnected it and took it for a test drive around my neighborhood at 15mph, didn't work. Going to the airport on the Interstate today, worked fine. Maybe some sort of minimum effective speed or some other rediculousness.
Old 08-29-2012, 05:59 PM   #19
awanted is on a distinguished road
awanted's Tacoma Gallery
Hi Terry, I was wondering if you could help me, I'm doing some research before I buy the parts to install the CC. I've checked the wiring in my truck (2012 A/C with 4 cyl and manual trans) and it looks like I have the wiring from the ECM to the steering wheel, my question is there is already a wire in pin 21 at the ECM (blue with a black tracer), I would assume that this is for the clutch however I cannot locate the clutch switch connector. What do you think?
Old 05-17-2013, 11:38 AM   #20
Tacoma0Josh is one of the sharper tools in the shedTacoma0Josh is one of the sharper tools in the shedTacoma0Josh is one of the sharper tools in the shedTacoma0Josh is one of the sharper tools in the shedTacoma0Josh is one of the sharper tools in the shedTacoma0Josh is one of the sharper tools in the shedTacoma0Josh is one of the sharper tools in the shedTacoma0Josh is one of the sharper tools in the shedTacoma0Josh is one of the sharper tools in the shedTacoma0Josh is one of the sharper tools in the shedTacoma0Josh is one of the sharper tools in the shed
Army:
Tacoma0Josh's Tacoma Gallery
Thought i would revive this thread as im doing the cruise install on my truck. So I tried to buy the rostra wiring kit for non-prewired tacomas and was informed the price on just the harnes has jumped up to $70 for a couple of wires. Some of you lucky few have been able to aquire the same harness through brandon distributing for $11 and now those days are over thanks to rostra.
Since I refuse to pay $70 for a couple of wires, does anyone know the correct size wires and type of terminal needed to insert in the ecu plug connectors?
Want to install cruise control on a 2012 tacoma fox408 2nd Gen. Tacomas 14 05-05-2013 08:49 PM
2012 cruise control tlh178 4 Cylinder 13 08-10-2012 10:02 PM
single cab 20" texas edition rims 07Tacoma806 Wheels & Tires 7 05-20-2012 05:32 PM
Regular Cab, automatic, and cruise control.. infocus 2nd Gen. Tacomas 0 11-03-2009 06:44 PM
Cruise Control-2008 Double Cab TonyTacoma 2nd Gen. Tacomas 1 04-09-2009 01:17 PM
