93 TOY pu. PROBLEMS
Old 07-31-2012, 02:00 PM   #1
ducrnd [OP] ducrnd is offline
ducrnd is on a distinguished road
ducrnd's Tacoma Gallery
93 TOY pu. PROBLEMS
I have a 93 Toy PU 4 cylEFI 4x4. Man trans. Recently I have had a issue of No starting. It will turn over then die. If I put it in reverse to start it , it hops then sputters , but starts.. I have put a new fuel fulter and it starts, BUT if I let the revs fall below 2500 it dies.. above 25 runs like a rabbit....... COuld this be a fuel pump issue ????
ducrnd@yahoo.com
Old 09-12-2012, 08:12 PM   #2
LDurchy is one of the sharper tools in the shedLDurchy is one of the sharper tools in the shedLDurchy is one of the sharper tools in the shedLDurchy is one of the sharper tools in the shedLDurchy is one of the sharper tools in the shedLDurchy is one of the sharper tools in the shedLDurchy is one of the sharper tools in the shedLDurchy is one of the sharper tools in the shedLDurchy is one of the sharper tools in the shedLDurchy is one of the sharper tools in the shedLDurchy is one of the sharper tools in the shed
LDurchy's Avatar
LDurchy's Tacoma Gallery
I too have 4 cyl, 1993, manual shift. Not had that problem. But still breaking in at about 120,000 mi. Possible old injectors? I do use BOSH Platinum tip plugs and only change them ...mmmm....maybe every 50,000 mi. or when I just respect their age and change them. Any good diagnostic shops in your area? The higher revs could be a clue. Have you tried that Seafoam stuff in the fuel, or an injector cleaner? I burn ethonal fuel and it seems to keep my system clean. Yup, likely giving up a tad on milage, but it will keep the system clean.
Good luck.
USA PA15 TOY-LEX problems? ChamYota Technical Chat 10 12-09-2011 07:06 PM
Want to buy an early 80's PU 4x4 MrGuitarguy General Automotive 1 07-02-2011 01:59 AM
93 toy pkup, will new taco 15" tire/rim fit? Mister Sir Wheels & Tires 6 12-16-2010 08:00 AM
'93 Toy Rock Crawler "Camo II" amatoer10 1st Gen. Builds 41 01-11-2009 08:34 PM
Photos of my 08 Toy, 84 and 93 model years with lift kit TmansToy08 2nd Gen. Tacomas 13 05-16-2008 07:34 AM
