4 cylinder and mudding
Old 11-09-2012, 04:37 AM   #1
MConde85 [OP] MConde85 is offline
MConde85 is on a distinguished road
Army: UAS
MConde85's Tacoma Gallery
I took my 2012 4cylinder mudding (stock) and I ended up having to change the altenator because it "has water damage." I couldn't find an aftermarket altenator so I had to pay about 698 for a new one.
Some of the...puddles were just above my tail pipe so I can understand how water got onto the alternator but what I don't understand is the placement of the alternator to begin with. If you look above the front wheel on the passanger side it is completely visable and open to the elements. It is more on the lower side of the motor then higher up.
Another issue I had was my "clutch throw out bearing." I washed my truck with a pressure washer as best I could to get the mud from under the truck. After it dried I started getting a strange noise when ever I depressed the clutch ("rusty throw out bearing") ?? I was also told that I should change out ALL the fluids, dif, trans., and engine, as the truck "had been under water." ( just up to the doors in muddy water)
It's going to cost me 400 to have the dealer replace the throw out bearing plus w/e the cost for fluids. Friend of mine said as long as it feels normal then my clutch should be ok, at least for a while??? Should I change all the fluids (due for an oil change anyway) .
Thanks for your help.-Mark
Old 11-09-2012, 05:26 AM   #2
Yep
buzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shed
buzzard1992's Avatar
buzzard1992's Tacoma Gallery
I wouldn't worry about changing any fluids except for maybe the rear diff since it was submerged. Do the rear diff breather mod. I'm assuming you were flyin through deep puddles right? It's not that good of an idea to do. As for the throw out bearing I have no idea
how NOT to mudding t4r4life Northern California 41 10-24-2011 09:24 PM
mudding issue DaytonLax14 1st Gen. Tacomas 14 03-27-2010 02:24 AM
Mudding questions!? Tberry5000 Off-Roading & Trails 41 03-22-2010 05:05 PM
Mudding!! YoungTaco 1st Gen. Tacomas 24 09-20-2009 06:23 PM
a little mudding bambamonly1 Tacoma Videos 5 07-20-2008 04:44 PM
