96 2rz O2 sensor
Old 11-28-2012, 05:47 AM   #1
jeffz0rz [OP] jeffz0rz is offline
jeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shed
jeffz0rz's Avatar
jeffz0rz's Tacoma Gallery
96 2rz O2 sensor
Throwing a cel, scanner says catalyst bank one low efficiency or something like that. I'm guessing its the O2 before the cat ? Sound right ?
Old 11-28-2012, 10:01 AM   #2
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
I have a feeling that it is not right. A P0420 is catalytic converter low efficiency. That USUALLY, but not always, indicates either a bad catalytic converter, or a problem with the O2 sensor AFTER the cat, which is what measures the cats efficiency. An exact code number would help.
lots of bump steer 96 2rz 2wd jeffz0rz 1st Gen. Tacomas 9 01-19-2012 04:21 PM
Help needed for a live reading of rear o2 sensor (bank 1 sensor 2) geoff06 Technical Chat 7 11-30-2011 04:57 AM
99 Tacoma 4x4 O2 Sensor Bank1 Sensor 2 GASKET?? vapovick 4 Cylinder 2 08-17-2010 05:04 PM
Part Number A/F sensor and O2 sensor derekp 1st Gen. Tacomas 4 04-07-2010 10:34 AM
3.4 coil packs, rear O2 sensor, water temp sensor glassdoc Buy / Sell / Trade 6 01-28-2009 06:51 AM
