Weird Idle issues
Old 12-12-2012, 08:47 AM   #1
Kirk1589 [OP] Kirk1589 is offline
Banned
Kirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shed
Kirk1589's Tacoma Gallery
Weird Idle issues
Truck: 2003 Tacoma SR5 2.7 4x4 with 85k miles
Issue: After cruising on the highway for 20 minutes or so, longer also when I come to a stop my idle fluctuates from 1200-2000 up and down then stays around 1250. If I cycle the key it will continue to do this also. Then around town I have had it dip down too 548 and almost stall before i recover the idle with a rev I get some fuel knock while doing this. What would cause this...I'm new to Toyota.
Thanks for help Dave
Old 12-13-2012, 09:48 AM   #2
Banned
bump
Old 12-13-2012, 12:11 PM   #4
Banned
Nope
Old 12-14-2012, 08:42 PM   #5
03TACO44 is on a distinguished road
Air Force: Fuels Laboratory Technican
03TACO44's Tacoma Gallery
My 2.4L did this one time. I cruise down the interstate for about 3 hours at 80MPH, then when I get off the interstate it would idle at 2-3000RPM's. After a few trips it quit doing it. Course this happened right after it sat for 2 years, only getting driven about 1,000 miles within that 2 years.
Old 12-15-2012, 07:40 AM   #7
Banned
Ill give them a good look over
Old 12-17-2012, 10:58 AM   #8
Banned
No leaks. All lines are intact. Even tried the propane trick.
Old 12-17-2012, 03:21 PM   #9
DGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shedDGXR is one of the sharper tools in the shed
DGXR's Tacoma Gallery
This idle problem just developed recently on a 2003 model? I'll bet something came loose... +1 on the vacuum line check. Look for cracks too, not just loose or missing connections. Also check for cracked or loose wires.
Any service or repairs done recently?
Old 12-17-2012, 03:27 PM   #10
Banned
Yes just recently but it's intermittent meaning it will happen today but may not tomorrow. Ill check for cracks and loose connections at the TPS and IAC. I hope the IAC isn't the cause because that sucker ain't cheap
Old 12-17-2012, 03:29 PM   #11
Pabst Blue Ribbon on ice
BAMFTACO is one of the sharper tools in the shedBAMFTACO is one of the sharper tools in the shedBAMFTACO is one of the sharper tools in the shedBAMFTACO is one of the sharper tools in the shedBAMFTACO is one of the sharper tools in the shedBAMFTACO is one of the sharper tools in the shedBAMFTACO is one of the sharper tools in the shedBAMFTACO is one of the sharper tools in the shedBAMFTACO is one of the sharper tools in the shedBAMFTACO is one of the sharper tools in the shedBAMFTACO is one of the sharper tools in the shed
BAMFTACO's Avatar
BAMFTACO's Tacoma Gallery
X2 it's always something small that you can't find and it's a bitch
Old 12-17-2012, 03:44 PM   #12
Banned
Yea I hope it's something small. I gonna look at it once this rain stops
Old 12-21-2012, 11:23 PM   #13
Banned
Diagnosed it. Pretty obvious now. Idle dropped to 300 then it recovered about a few seconds later.threw a new OEM IAC in it PERFECT now
Old 12-24-2012, 10:18 AM   #15
Banned
Gosh dang it I lied its back
Old 12-25-2012, 02:41 AM   #16
Junya808 is on a distinguished road
Junya808's Avatar
Junya808's Tacoma Gallery
Try checking these also:
Spark plugs and wires
Air filter (also check your MAF sensor while your at it)
Fuel filter
Fuel injectors
Old 12-26-2012, 06:22 PM   #17
Banned
Where is the fuel filter? Plugs have 3k on them. I cleaned MAF with MAF cleaner along with the throttle body.
Old 01-24-2013, 12:41 PM   #18
MMumau is on a distinguished road
Air Force: Airman
MMumau's Tacoma Gallery
Any residue on the plugs?
Old 01-29-2013, 09:59 AM   #19
Banned
Nope
Old 02-28-2013, 08:29 AM   #20
TACOMA31750
1rooster is one of the sharper tools in the shed1rooster is one of the sharper tools in the shed1rooster is one of the sharper tools in the shed1rooster is one of the sharper tools in the shed1rooster is one of the sharper tools in the shed1rooster is one of the sharper tools in the shed1rooster is one of the sharper tools in the shed1rooster is one of the sharper tools in the shed1rooster is one of the sharper tools in the shed1rooster is one of the sharper tools in the shed1rooster is one of the sharper tools in the shed
1rooster's Avatar
1rooster's Tacoma Gallery
This same thing happened to me back several years ago. i had a 2001 2.7 single cab. I ended up cleaning the throttle body good and and the maf and it fixed my problem. but it didnt seem to help you though! not sure what it would be
Weird Idle?? mcguire 1st Gen. Tacomas 3 07-17-2011 11:21 AM
truck idle weird after disconnecting battery jayyyg84 Technical Chat 4 06-24-2010 07:53 AM
new 2010 4x4 torque converter lock up at idle and other weird sounds mugenrios2k 2nd Gen. Tacomas 19 12-21-2009 05:44 PM
Weird idle 06 V6 CraigTRD 2nd Gen. Tacomas 4 12-19-2009 11:08 AM
Weird idle/stopped noise Gr8WhiteTaco 1st Gen. Tacomas 15 05-18-2009 01:42 PM
