98 Tacoma 2.7L won't start
Old 01-23-2013, 04:30 PM   #1
haroldpo [OP] haroldpo is offline
haroldpo is on a distinguished road
haroldpo's Tacoma Gallery
The check engine light start flashing and it started running rough, but made it home. Next day it would not start. Things i have checked or replaced.
Since toy decided not to put a fuel test port on the fuel rail i checked the fuel pressure at the fuel filter, all OK
Have fire to all plug wires, installed new plugs anyway.
Cam sensor had oil all over it so i installed a new one, not easy, no change.
Cleaned TB
The codes where PO300/
PO302/PO304 cylinder #2&#4 misfire.
1/2 tank fuel
Compression is 175/180/176/180
All fuses is good.
Still the truck will not start, where should i look next?
Truck has 180,000
Old 01-24-2013, 04:24 PM   #2
Bamatoy1997 you out there?
Old 02-01-2013, 10:00 AM   #3
Pulled it to a repair shop and he said i had bent valves, jumped time he thought. Wants $1800 for repair. I don't see how a bent valve would let me have 175-180 psi on all cylinders. Pulling it home tomorrow.
Old 02-09-2013, 05:58 AM   #4
Fixed
Old 02-11-2013, 10:02 PM   #5
tan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shed
tan4x4's Avatar
tan4x4's Tacoma Gallery
Well, what was it, and what did you do
Old 02-13-2013, 07:41 AM   #6
Just think, 188 views and no help offered.
Old 02-13-2013, 01:24 PM   #7
SpeedoJosh is one of the sharper tools in the shedSpeedoJosh is one of the sharper tools in the shedSpeedoJosh is one of the sharper tools in the shedSpeedoJosh is one of the sharper tools in the shedSpeedoJosh is one of the sharper tools in the shedSpeedoJosh is one of the sharper tools in the shedSpeedoJosh is one of the sharper tools in the shedSpeedoJosh is one of the sharper tools in the shedSpeedoJosh is one of the sharper tools in the shedSpeedoJosh is one of the sharper tools in the shedSpeedoJosh is one of the sharper tools in the shed
SpeedoJosh's Avatar
SpeedoJosh's Tacoma Gallery
The 4cyl section doesn't get checked much. Better luck can be had in the 1st Gen section.
Glad you got it all sorted though.
2001 Tacoma Won't Start... Sometimes Hot Taco Technical Chat 1 11-28-2012 04:38 PM
2003 2.7L Auto, won't start Mo03 1st Gen. Tacomas 3 08-06-2012 07:18 AM
'95 Tacoma won't start JaxFlJon 1st Gen. Tacomas 12 11-10-2011 11:43 AM
Tacoma won't start SPiNRiX Technical Chat 12 12-15-2010 04:15 PM
98 Corolla LE won't start... sirsaechao Off-Topic Discussion 4 07-19-2010 11:33 AM
