Yes, Another Manual Tansmission Question!
Old 01-31-2013, 07:09 AM   #21
jassco has a spectacular aura aboutjassco has a spectacular aura aboutjassco has a spectacular aura about
jassco's Avatar
jassco's Tacoma Gallery
Originally Posted by 91r100gs View Post
Hate to burst your MPG bubble, but I have a large hill that I go up every day at 40 MPH. If I use 4th gear my UltraGauge will show 14.5 MPG up the hill. In third it shows 12.5 or so. Lugging up the hill definitely shows more MPG. At a steady 30 MPH on level surface in third it will show low 20's and 4th will show low 30's. RPM's use more fuel plain and simple.
They do not in most cases with a 2.7L 4x4. Your RPM gauge is not a fuel use gauge. If you are moving down a highway at 2000 RPM and I sit in my driveway and rev to 2000 you will run out of gas sooner.
You are 2wd and the OP asking the question is 4x4 access cab. He explicitly asked "I am trying to get the best gas mileage without hurting the transmission." Everything with this motor has to do with load and a 4x4 system has much more loss then what you are driving. You will probably see a lot different results with 400+lbs less weight and a different drive-train. These engines/manuals with 4x4 perform much better at a higher rpm and provide better overall mileage then following the low rpm shift method of the v6. It is also bad on the bearing/rings to lug the engine and will probably be leaking oil past the seals down the road if done constantly.
The answer to his question is: just a low enough rpm to not lug the engine no matter what gear he uses. 1400 is low for any gear and lugging with a 4x4 Access cab 2.7L engine.
Question on driving a manual ortlie09 2nd Gen. Tacomas 78 01-11-2012 08:29 PM
Question about Manual Trans TheJDawg 2nd Gen. Tacomas 22 03-18-2011 01:31 PM
Manual Transmission Question bcmedic13 2nd Gen. Tacomas 8 12-15-2010 10:42 AM
manual question TOYOTA 09 2nd Gen. Tacomas 18 03-29-2010 01:23 PM
Manual trans question tacomabud 1st Gen. Tacomas 8 01-17-2010 01:57 PM
