2000 Taco 2.4 auto stalls only in warm weather.. Help!
Old 07-02-2013, 05:19 PM   #1
Ryfly05 [OP] Ryfly05 is offline
Ryfly05 is on a distinguished road
Ryfly05's Tacoma Gallery
Copied from 1st gen section:
Title pretty much sums up the problem. It runs and drives fine if the outside temp is below about 70*F, but once it gets above that, it will stall whenever you try to accelerate from a stop or slow roll. It always starts right back up after it stalls too.
It still idles fine and comes to a stop without stalling, but once you try to accelerate it stalls and it does it every time. It also seems to only stall when it goes into closed loop mode after the engine is warm. Even if its real hot outside, if the engine is cool, it wont stall until it warms up.
Thinking about unplugging the O2 sensor to force open loop all the time and see what it does. Also, not sure if this is normal but unplugging the MAF while it's idling will cause it to die. Runs worse with MAF unplugged also.
The truck is all stock, automatic, year 2000 and has 580,000 miles on it! Any other ideas I can try to figure out whats causing this?? Thanks!
Old 07-02-2013, 05:49 PM   #2
ramirezsergio63 is on a distinguished road
ramirezsergio63's Avatar
ramirezsergio63's Tacoma Gallery
Get a new truck isbthe best i can say
Old 07-11-2013, 02:15 PM   #3
tan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shed
tan4x4's Avatar
tan4x4's Tacoma Gallery
Amazing that thing is running at all with 580k miles! Congrats.
You could be in a Toyota commercial.
I'd start with a regular tuneup (change plugs, plug wires, pcv, air filter) if you haven't done it in a while.
After that, I'd suspect a temp sensor (intake or coolant). On mine, the intake sensor is part of the MAF sensor (ie - expensive part). Coolant temp sensor is cheaper to replace.
Engine Stalls when warm randomco 1st Gen. Tacomas 10 05-27-2014 09:33 AM
2000 2.4 Taco stalls only in warm weather.. Help! Ryfly05 1st Gen. Tacomas 11 09-28-2013 06:30 PM
96 4cyl, lacks fuel to start in warm weather weldway 1st Gen. Tacomas 5 06-15-2013 12:20 PM
Finally some warm weather JayARRGHH 1st Gen. Tacomas 0 03-16-2011 11:01 PM
Engine stalls when warm TubMaster 1st Gen. Tacomas 13 09-24-2010 01:03 PM
