Spark plug question!
Old 03-04-2009, 10:28 PM   #1
H-Dogg [OP] H-Dogg is offline
H-Dogg is on a distinguished road
H-Dogg's Tacoma Gallery
ok, so I pulled the spark plugs out of my new 2002 taco with 62000 miles just to see what things looked like and it had burn marks on the side of the insulator with a small about of white ash on the electrode. I'm not sure what this means and my brother-in-law said that the spark could be jumping to the piston instead of the electrode. Is that common? If it is how would it be fixed? And if that's not the problem what does it mean? Thanks for any help given!
Old 03-04-2009, 10:34 PM   #2
Low and slow
dually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the shed
dually's Avatar
Army: 14S
dually's Tacoma Gallery
Pics would surely help.
Old 03-04-2009, 11:02 PM   #4
Here are some pics I hope they help!
Old 03-04-2009, 11:52 PM   #5
bite me
humanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shed
humanoid's Avatar
humanoid's Tacoma Gallery
Got this explanation by google-ing:
A white colored plug is caused by engine overheating. Failure to repair this engine will result in severe engine damage. Common causes for this are:
Incorrect spark plug (too hot heat range).
Low octane fuel.
Timing is not set properly.
Cooling problems, (dirty cylinder fins, no or low water if water cooled, low or no engine oil).
Carburetor air/fuel mixture is too lean (too much air).
Leaking crankshaft seals, no oil, base or head gasket leaks, or crankcase leaks on two stroke engines.
Old 03-05-2009, 11:01 AM   #6
wawireguy is on a distinguished road
wawireguy's Tacoma Gallery
Looks odd to me. Should be toasty brown or whitish. Looks like it was carboned up due to all the black on it. Then it started running right and the carbon burnt off.
Old 03-05-2009, 11:09 AM   #7
chris4x4's Avatar
chris4x4's Tacoma Gallery
What engine did these come out of??
Old 03-05-2009, 11:11 AM   #8
XXXXXXXXXXXXXXXXXXXX
T@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shed
T@co_Pr3runn3r's Avatar
T@co_Pr3runn3r's Tacoma Gallery
Doesn't look like iridium, hope it came from v6. Did gen 1 2.7ls come with iridium? Doesn't look all that crazy to me, just like valve seals letting a little oil in that is carboning up the plug a bit.
Old 03-05-2009, 11:15 AM   #9
chris4x4's Avatar
X2. The 1st gen 2.7 used a standard copper plug.
Old 03-05-2009, 10:14 PM   #10
These are the v-power NGK spark plugs that the 2.7L come stock with.
Old 03-05-2009, 11:47 PM   #11
Still For Sale
BUK 0H5 is a name known to allBUK 0H5 is a name known to allBUK 0H5 is a name known to allBUK 0H5 is a name known to allBUK 0H5 is a name known to allBUK 0H5 is a name known to all
BUK 0H5's Avatar
Army: Chinook Crew 101st ABN
BUK 0H5's Tacoma Gallery
http://www.aa1car.com/library/reading_spark_plugs.jpg
Try this, It looks O.K. from what I can tell from the picture
Question about Spark Plug Wires Ngotoma 1st Gen. Tacomas 4 01-05-2012 10:06 PM
Spark Plug Question Dadic 78 2nd Gen. Tacomas 7 12-20-2010 05:42 PM
Spark plug question BigJLarse83 2nd Gen. Tacomas 8 07-12-2010 05:51 PM
Spark Plug question cajunboi 1st Gen. Tacomas 10 07-27-2009 07:05 AM
Spark plug question rob mcnair 1st Gen. Tacomas 15 11-30-2008 02:33 PM
