4.7 Tacoma,stumbles when accelerated
Old 09-16-2013, 01:55 PM   #1
scbill [OP] scbill is offline
scbill is on a distinguished road
scbill's Tacoma Gallery
2002 2.7 Tacoma, Starts, and idles ok, but starves out when accelerated, will go to about 3grand on gradual before it starves. I have cleaned throttle body, & MAF. 89k miles, no evidence of shadetree tampering, all hoses,clamps are as they should be. Could it be the filter clogged, or weak fuel pump,or??? You can hear pump running when switched on.
Thanks, Bill
Edited to say...what is the psi for the fuel pump, and where is the test port located?
Old 09-16-2013, 06:00 PM   #2
camojared is a jewel in the roughcamojared is a jewel in the roughcamojared is a jewel in the roughcamojared is a jewel in the rough
camojared's Tacoma Gallery
I wish I could get a 4.7 v8 in my tacoma Sorry Im not much help just thought id point that out.
Old 09-17-2013, 06:23 AM   #3
Don't know where I got 4.7 from...thanks for pointing that out, had a rough day.
Bill
Old 09-17-2013, 02:44 PM   #4
At least you got the 4cyl section right, your already off to a better start than me. Have you checked spark plugs? I would try some fuel system cleaner.
Old 09-18-2013, 06:39 AM   #5
Gonna try fuel filter first, Checked TPS, it's Ok, talked to a mechanic friend, he thinks maybe MAF sensor, pump pres. seems to be OK. Took MAF with me to Pull-A-part, couldn't find one, put it back..runs worse than ever now.(thinking MAF)
Can anyone tell me if there's a connection to check pump preassure, and where it is?????
Bill
Old 09-18-2013, 09:52 PM   #6
kylenotjon will become famous soon enoughkylenotjon will become famous soon enough
kylenotjon's Avatar
kylenotjon's Tacoma Gallery
Did you check for a clogged converter or muffler? If you have a scan tool, give this video a look.
http://www.youtube.com/watch?v=9TlygJMxTps
Old 09-20-2013, 01:33 PM   #7
Changed fuel filter, ran OK for short time, then back to same. Filter was totally blocked, looked like muddy water ran out of line from tank, guess it's pull the tank time. Is there a diagram of the hoses, and do you need special tools to disconnect anything? There was a black sediment also in the filter. Truck is an insurance total, and rebuilt, thinking it sat for a spell, no telling where, or what got in the tank.
Bill
Old 09-23-2013, 07:48 AM   #8
Fuel filter had a black powdery residue..Could this be pump going bad??? gonna pull the filter to see if it's clogged again. Got it running good enough to drive a short distance, stopped and let it sit for about 15 minutes, wouldn't start, hit it with starting fluid, started,and ran OK.
Pulled #1 plug, it was black, running too rich looking. No way to check converter/muffler, runs really peppy, don't think it's that.
One more thing, sprayed starting fluid into throttle body, started, and died, sprayed again,put intake tube back in place, started, and ran OK.
If I had any hair, I would be pullin it out...Bill
Old 09-23-2013, 01:19 PM   #9
Update...pump pressure 10/12 PSI...should be 25+ thinking the black stuff in the filter was pump parts. Pulled new filter, it is clean, checked pressure on both sides of filter checked same PSI on both sides. Tank pullin time...Oh well.
Bill
Old 10-01-2013, 12:49 PM   #10
Bad fuel pump...all OK..B
2.7 stumbles like its starving for fuel. TeddyBear 4 Cylinder 14 09-11-2013 03:01 PM
Help, tacoma stumbles and dies after fuel filter change. Beluga 1st Gen. Tacomas 10 03-24-2012 08:29 PM
accelerated rust? Toyota Dave 1st Gen. Tacomas 0 06-02-2011 07:08 PM
Engine stumbles on inclines yotatomy 1st Gen. Tacomas 7 10-08-2010 02:53 PM
braking the car accelerated robert Technical Chat 7 05-20-2007 10:48 PM
