The 2.7L DipStick.
Discussion in '4 Cylinder' started by Runn0r, Sep 20, 2013.
  1. Sep 20, 2013 at 9:02 PM
    Runn0r
    Runn0r [OP] Well-Known Member
    NC
    07 Prerunn0r
    Forgive me for being a dipstick or a douchebag or a cornswaggle for asking this...I've read around and have not pinpointed...the thread...I know it exists... IT has to. ..
    How...do you increase the friction or texture on the 07'ish oil dipstick so that the ******* oil sticks to it and shows the actual oil level? These 2 dimples are bullshit.
    Ive been using 5W30 as recommended, but I have never seen such a shitty dipstick compared to the knurling found on ALL others i've owned.
    Someone level me.
  2. Sep 20, 2013 at 9:06 PM
    trooper12
    trooper12 Well-Known Member
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    maxtrac 4" lift spindles, wheelers 1.5" 3 leaf pack. nothin special...
    just use fine sandpaper to scuff the surface so the oil will stick. super easy...
  3. Sep 20, 2013 at 10:07 PM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    I took a small single cut file and roughed up the area between the two dimples, cleaned off the filings with some acetone and paper towels. You know what? It didn't really help.
    Yeah, sandpaper would work too. I just tend to overdo stuff. :)
    Or you can do like my redneck brethren and rub that SOB with a chunk of whatever the nearest rock is, wipe it off on your sleeve, and call it good. Bonus points if you spit on it before you wipe it off.
  4. Sep 21, 2013 at 7:03 PM
    Runn0r
    NC
    07 Prerunn0r
    Haha that's what I thought in my head basically. That bastard piece of steel is too smooth. I mean...really they couldint have rolled it with a carbide imprint showing "full" and "low" I guess its one of those things the Japanese do by taste.
  5. Nov 17, 2013 at 1:04 PM
    andyman
    andyman Active Member
    Andy
    S.E. Pennsylvania
    '12 Tacoma TRD Off-Road
    I'm glad to see some other people have this problem too, I've been too embarrassed to ask about it. I consider my car knowledge to be pretty good and I have one hell of a time trying to read that damn dipstick. Mine is basically just one small smear of oil going half-way up the dipstick. More or less useless. Thanks for having the balls to ask. Have you found a good solution?
    cryptolyme likes this.
  6. Nov 17, 2013 at 1:15 PM
    OffroadToy
    Yep... The V6 has the same issue. Try sandpaper or a file and crisscross the etches. The trick for a good reading after removal: wipe the dip stick off and wait 10 minutes before inserting for the read (gives the oil that gets dragged up the tube with the stick time to drain back down.)
  7. Nov 17, 2013 at 7:33 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I taped mine off and sandblasted the area between the holes. I'll post a pic of it tomorrow. :)
    Greg
  8. Nov 18, 2013 at 11:49 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    The dipstick on my 2009 2.7l reads 1 quart low, ie. when I change the oil and put in 6 quarts it read about 1 quart above the upper dot. Anyone else notice this?
  9. Nov 18, 2013 at 12:11 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Normal. Now that you have found the proper full level for your engine make note of the level for 6 Qts on the dipstick and move on to other things. Just avoid putting much more in then that mark from now on as some oil won't drain out of the engine during subsequent changes.
  10. Nov 19, 2013 at 4:47 PM
    tooter
    Greg
    Los Angeles
    Takes about 10 minutes to tape it off, sandblast the area between the dots, and clean it. :thumbsup:
    I NEVER wonder what the oil level is. :)
    Greg
  11. Nov 20, 2013 at 5:25 PM
    RdRunr
    RdRunr Well-Known Member
    Dan
    still in the Matrix
    2014 Base, white, reg cab, 2.7L, 5-spd
    LCE header, Flowmaster 50 Series Delta Flow muffler
    Thanks for the picture! I have been struggling with my wife's 07 Camry dipstick, and now my Tacoma dipstick is just as bad. Don't have a sandblaster, so I'll try the sandpaper method.
    Anyone have an idea how much different it will read between a hot and cold engine? Maybe someone with a sandblasted dipstick can check for us? :D
  12. Nov 20, 2013 at 6:50 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    andyman,
    Question for you, on your dipstick when you check it, does it smear on both side. When I check mine it will smear on one side. If I look on the other side it is perfect. Also removing it slowly enough and both sides are clear quite often. The subject baffles me, is mine being so much easier to read, a rare exception, or are we only hearing from folks who are having problems. Lets hear from the folks who do not have a problem.
  13. Nov 21, 2013 at 9:49 AM
    Runn0r
    NC
    07 Prerunn0r
    Nice. I dont have a blaster but im going to rough it up. I dunno what Toyota was thinking not texturing it!
  14. Nov 21, 2013 at 11:53 AM
    OffroadToy
    Like mentioned earlier just wait 10 minutes before reinserting the stick to check the level... you need to let the oil that gets dragged up the tube when the stick is removed time to drain back down. Doing this will give you the exact same reading on both sides of the stick with no smear.
