Cold Air Intakes?
Discussion in '4 Cylinder' started by 4bangerowner, Jan 15, 2014.
  1. Jan 15, 2014 at 11:32 PM
    4bangerowner
    4bangerowner [OP] Well-Known Member
    Eddie
    Orange county
    PreRunner 2.7 4 cyl
    none yet
    Any good cold air intakes. I want more power then i already have in my stock 2.7L. thanks!
  2. Jan 16, 2014 at 12:09 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    The name cold air intake is kind of a deception. Should be called Air intake performance kit, or as K and N calls it, Fuel Injection Performance Kit (FIPK). And they are all good, but don't really offer too much gains until you start adding other things along with it such as headers, or you're running your engine in the higher RPM range. But they do give the engine a much nicer Brap sound. But I do believe URD (Under Dog Racing) offers a true cold air intake that snakes the cone filter in between the grill and the radiator. Might be something that would interest you. Good luck
    Nskcorona likes this.
  3. Jan 16, 2014 at 12:18 AM
    .MarkyMark.
    .MarkyMark. Jesus follower
    Mark
    Oceanside, CA
    2007 Regular Cab, 5-Lug
    ReadyLift SST w/AAL, Rancho RS5000 shocks, Volant CAI, 1.25" Hub-Centric Spacers, FJ Cruiser Seats, Tint, Stereo, more to come
    Volant for the 2.7l, so legit. Cone filter hidden in the box, cool air from the grille with the scoop attachment and there is a hidden pipe on the side that goes into the fender.
    Sheamus_O_Grady likes this.
  4. Jan 16, 2014 at 12:22 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Get an AFE pro dry filter and you should be good.
  5. Jan 16, 2014 at 12:24 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    That's a nice set up there
  6. Jan 16, 2014 at 12:25 AM
    .MarkyMark.
    Mark
    Oceanside, CA
    Thank you, sir.
  7. Jan 16, 2014 at 3:46 AM
    Maineiack
    Maineiack Well-Known Member
    Maine
    2013 stock reg cab 4x4
    Where 'bouts did you get that? Looks like a nice setup. Could pass for stock if the top didn't say volant.
  8. Jan 16, 2014 at 10:39 AM
    .MarkyMark.
    Mark
    Oceanside, CA
  9. Jan 16, 2014 at 11:05 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    The only thing it's going to do is make noise unless you are tuned for it...
    And like was mentioned above most of then draw warm air from the engine bay, not cool air like the stock air box does
  10. Jan 16, 2014 at 12:16 PM
    4bangerowner
    Eddie
    Orange county
    PreRunner 2.7 4 cyl
    none yet
    is there any that will give you a little more power? Or are headers/exhaust the way to go.
  11. Jan 16, 2014 at 12:23 PM
    .MarkyMark.
    Mark
    Oceanside, CA
    I'm going to partially disagree here... Granted the noise is the most obvious change, the power increase is notable as well to a stock tune. I agree that the right system must be chosen to improve performance. It would be pointless to tune after every mod because that would start to get expensive, unless you can tune it properly yourself. Wait until you've done all your major performance mods before tuning and then once you do you'll unleash some better results. You will feel improvements along the way though.
    Headers are a must. Read what I posted here http://www.tacomaworld.com/forum/4-cylinder/85764-doug-thorley-vs-lc-engineering-6.html#post8018235
  12. Jan 16, 2014 at 12:39 PM
    http://m.youtube.com/watch?v=gCi2yo4UqPI
    Cold air intakes are a lie^^^^^^
  13. Jan 16, 2014 at 1:13 PM
    AL W
    AL W 10 years old and still running strong
    Youngstown, OH
    2013 PreRunner
    Truxdeo Lo Pro QT Tonneau Cover Hewitt Technologies Gen2 SAIS By-pass kit
    I agree with Capt Fluffy. Cold Air intakes are wasted money. The guys in this video are very careful to try most alternatives and they still only get 1.7% performance increase by hanging the filter outside the engine bay in front of a fan.
    AL W
  14. Jan 16, 2014 at 2:22 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    From my own experience I'd say that headers are the best bang for the buck mod as long as you don't open up the rest of the exhaust system and lose your low end torque.
    While I don't know about 4-2-1 Doug Thorley headers because there doesn't seem to be any 2.7 specific dyno charts on them, I did run a dyno test with an LCE 4-1 folded long tube header on my engine...
    ...and it lowered the torque peak by 650 rpm from 3,800 rpm down to 3,150 rpm. The run with the header is the blue lines.
    The red lines are the dyno run with the combination of the header and an intake manifold spacer.
  15. Jan 16, 2014 at 8:59 PM
    tooter
    Greg
    Los Angeles
    I run a warm air intake for better gas mileage.
    8a098052-48fe-43ec-a082-e93bd8aaf3e0_zps_432e7fed9e245571ffee1f2620ac3b05b5e88170.jpg
  16. Jan 21, 2014 at 6:40 AM
    sgoodwin1
    sgoodwin1 New Member
    03 Tacoma Prerunner 2.7L
    Only way a CAI does anything is if you get tuned for it. The ECU will compensate for the increased airflow using Fuel Trims to maintain Stoich 14.7 AFR....but they do sound cool lol I bought my truck used and it had a K&N intake and throttle body spacer sounds like a vaccumm cleaner LMAO
  17. Jan 26, 2014 at 8:12 AM
    Indy
    Indy Master of all I survey.
    A little extra power tends to be a big waste of money. You wont in any conceivable sense notice 5hp. Your engine makes a fraction of what it can at any given time driving around. A 500hp engine is making around 50hp 99% of the time, making it a 505hp engine, it will still be making 50hp 99% of the time.
    If you figure a lot of 'good' bolt on will net a 10% improvement, a 140hp engine becomes, after several hundred dollars, 141.4hp. Yay.
    I still throw money at my toys, but not because i actually expect a real effect.
  18. Jan 26, 2014 at 8:47 AM
    tooter
    Greg
    Los Angeles
    The best bone stock 2.7 dyno run I've seen so far is: 119hp 133tq
    I did dyno runs on my 2.7 with only these mods:
    LCE long tube header...
    No power steering or air conditioning.
    ...and it made: 135hp 158tq
    So the combination of those mods netted gains of 16hp and 25tq.
    Intake: $220
    Header: $473
    ...for a total of $693.
    Greg
  19. Jan 26, 2014 at 9:40 AM
    vstrom
    vstrom Well-Known Member
    10% of 140 =14
    So total is 154
    10% is a huge improvement on a small motor.. but I doubt you'd get that high a percentage.
    Edit.. just read Tooter's numbers.. looks like he got close to 14% on HP and 19% on TQ! Very impressive!
  20. Jan 26, 2014 at 1:36 PM
    tooter
    Greg
    Los Angeles
    And the intake manifold spacer added a couple more of each to make 137hp and 160tq.
    So from 119 hp to 137 hp is 18 hp is 15% increase in horsepower...
    ...and from 133 tq to 160tq is a 20% increase in torque and that higher peak torque is reached 1,100 rpm sooner, at only 2,900 rpm instead of the 3,800 rpm peak on a bone stock engine...
    ...and this is with just the stock ECU, no tuning, and cheap regular 87 octane pump gas, so I'm really pleased with how this particular combination of mods has worked out. :)
